Kaplans Auktioner
    Stäng notis
Stäng notis
Klocksnackbloggen
Klocksnackbloggen >>
Stäng notis
Lyssna på podden! >>
Produktionsbolag: Lejon Media
Avslutad Casio G-Shock GBA-400-3BER sista prisändring
Diskussion i 'Handla - Säljes, bytes' startad av Nazzgul, 24 mars 2016.
  1. Nazzgul
    Nazzgul Ewok
    En lite spännande färg på klockan men vi klickade inte riktigt. Har bara haft den i dryg två veckor så slitage är minimalt då jag bara haft den på armen två gånger.
    Priset jag begär är 700kr plus valfri frakt som köparen står för.
    retur inom 24h om missnöje uppstår köparen betalar returfrakt
    World Time
    35 time zones (100 cities + UTC), city code display, daylight saving on/off
    Shock Resistant Shock Resistant construction protects againt impact and vibration.
    Battery Life 2 years on SR927W × 2 (Mobile Link used 2 hours a day.); Light: 1 time (1.5 seconds)/day; Alarm: 10 seconds/day
    LED Light Selectable illumination duration (1.5 seconds or 3 seconds), afterglow
    Stopwatch 1/100th Sec Stopwatch
    Water Resistant 200 Metre / 20 Bar, 20 Bar Water Resistant means that the watch is also suitable for swimming or snorkelling
    Countdown Timer Measuring unit: 1/10 second, Input range: 1 seconds to 100 hours (1-second increments, 1-minute increments and 1-hour increments)
    Hourly Time Signals The Hourly time signal causes the watch to beep every hour on the hour.
    Mineral Glass Hard glass resists scratching.
    12/24 Hour Format Times can be displayed in either a 12- Hour or 24 Hour Format.
    5 Daily Alarms The daily alarm reminds you about recurring events with an acoustic signal at the time you have set. You can also activate hourly time signals (each hour). This model has 5 independent alarms.
    Auto-Calendar Full Auto Calendar (pre-programmed until the year 2099)
    Mobile link Wireless linking with Bluetooth Smart ready devices
    Case / bezel material Resin / Stainless steel
    Resin Band Synthetic resin is the ideal material for wrist straps thanks to its extremely durable and flexible properties.
    Regular timekeeping Analogue: 2 hands (hour, minute (hand moves every 20 seconds)); Digital: Hour, minute, second, pm, month, date, day
    Flash Alert Flashes with buzzer that sounds for alarms, hourly time signal
    Airplane Mode
    Accuracy
    +/- 15 seconds per month (with no signal calibration)
    Size of case 55.0 × 51.9 × 18.3 mm
    Total weight 66 g
    Low Battery Alert A warning appears on the display whenever battery power drops below a certain level.
    Button operation tone on/off
    Senast ändrad: 10 april 2016
Sjöö Sandström Royal Straps
