Kaplans Auktioner
    Stäng notis
Stäng notis
Lyssna på podden! >>
Produktionsbolag: Lejon Media
Säljes Casio ProTrek Titanium Triple Sensor PRG80YT-1VDR. NU 1500kr!
Diskussion i 'Handla - Säljes, bytes' startad av Totte, 3 september 2016.
  1. Totte
    Totte Y-Wing pilot
    Skåne
    Ett styck friluftsmonster säljes! Klockan är sparsamt använd. någon hairline på länken. Saxar info från nätet. Kommer i original box med alla länkbitar. Pris: 2000 kr inkl. Rek NU 1800kr NU: 1500kr!! retur inom 48h. Tack KS :)
    Casio ProTrek Titanium Triple Sensor PRG80YT-1V PRG-80Y WatchB
    lack Titanium Braclet and case front
    Electroplated not painted (thus making the colour very durable)Electro-luminescent backlight
    Full auto EL light, afterglow
    Solar powered
    Low-temperature resistant (-10 C/14 F)
    Digital compass
    Measures and displays direction as one of 16 points
    Measuring range: 0 to 359
    Measuring unit: 1
    20 seconds continuous measurement
    Graphic direction pointer
    Bidirectional calibration and northerly calibration function Altimeter
    Measuring range: -700 to 10,000 m (-2,300 to 32,800 ft.)
    Measuring unit: 5 m (20 ft.)
    Auto memory measurements (up to 40 records, each including altitude, month, date, time)
    High Altitude / Low Altitude Memory
    Cumulative Ascent / Descent Memory
    Relative Altitude Display
    Altitude Tendency Graph
    Altitude Differential Graphic
    Altitude alarm
    *Changeover between meters (m) and feet (ft.) Barometer
    Display range: 260 to 1,100 hPa (7.65 to 32.45 inHg)
    Display unit: 1 hPa (0.05 inHg)
    Atmospheric pressure tendency graph
    Atmospheric pressure differential graphic
    *Changeover between hPa and inHg Thermometer
    Display range: -10 to 60 C (14 to 140 F)
    Display unit: 0.1 C (0.2 F)
    *Changeover between Celsius ( C) and Fahrenheit ( F) Watch functions
    Duplex LC display
    World time
    29 time zones (30 cities), city code display, daylight saving on/off
    1/100-second stopwatch
    Measuring capacity: 9:59'59.99''
    Measuring modes: Elapsed time, split time, 1st-2nd place times
    Countdown timer
    Measuring unit: 1 second
    Countdown range: 60 minutes
    Countdown start time setting range: 1 to 60 minutes (1-minute increments)
    Others: Auto-repeat, progress beeper
    Daily alarms - 5 independent daily alarms
    Hourly time signal
    Battery power indicator
    Power save function (automatically disables LCD if the watch is left in the dark for approximately 60 to 70 minutes, and sensor measurements if the watch is left in the dark for six or seven days)
    Auto-calendar (to year 2099)
    12/24-hour format
    Regular timekeeping: Hour, minutes, seconds, pm, month, date, day
    Accuracy: 15 seconds per month
    Approx. battery operating time: 6 months on Rechargeable Battery (Operating period with normal use without exposure to light after full charge)
    21.5 months on Rechargeable Battery (Operating period when stored in total darkness with the Power Save function ON after full charge) Size of case/total weight : 62.3 X 52.2 X 14.2 mm / 117 g
    Senast ändrad: 18 september 2016
    Stroboman gillar detta.
Sjöö Sandström Royal Straps
