Jonaz
Stilig blå dykare ifrån det soliga Nya Zeeland
Kommer på originalgummi ( svart ) med viklås och ett läder ifrån Dstrap.
Inga dings men det finns spår av skrivbordsdykning. Tidhållningen är inte mätt men jag upplever inte att den inte sköter sitt jobb. Skruvad krona, datum växlar som det skall. Bor mest i en winder.
Wristskott.
Teknisk info knyckt ifrån magrette.eu
- Automatic mechanical watch
- Limited to 750 pieces world wide
- 24-jewel Miyota 9015 movement running at 28.800 BHP with second stop mode (hacking function)
- Case in stainless 316L steel with the sides brushed, the top in polished finish
- Black ceramic (matt finish) bezel with painted C3 luminous markers
- Functional pressure escape valve, protecting the watch against pressure differences that can occur below 300 meters of depth
- Screw-in type crown with logo
- "Double domed" sapphire crystal (strongly scratch-resistant)
- Anti reflection coating on the inside
- Water resistant to 500 meters
- Diameter: 44mm without crown
- This watch will be supplied with an all new black PU rubber strap with logo, name and customized stainless steel deployment buckle
- Delivered in the new Magrette travel case
STRAP OPTIONS: Please select in the drop down box if you want to receive additional straps.
- We created special package deal prices that give you additional discount.
- We added the option to order a special hand made DStrap leather strap specifically designed for Magrette.
- All buckles will match the case of the watch (brushed steel).
The automatic Miyota 9015 movement:
- Automatic winding and hand winding
- 28.800 BPH
- 24 Jewels
- Hour, minute and sweeping second hands
- Date function
- Second stop mode (hacking function) when setting time
- Shock absorber for balance staff
- Running time of more than 42 hours when fully wound
Nypris 500 euro. Kan bli din för 2800:- finns i gbg. Finns referenser på mig i goodguy's.
Skulle klockan inte motsvara beskrivet skick tar jag tillbaka den inom 48h med rekad post. Vid F2F köp gäller ej retur.
Wristskott.
- 28.800 BPH
- 24 Jewels
- Date function
