    Stäng notis
Avslutad Maratac Mid Pilot *såld*
Diskussion i 'Handla - Säljes, bytes' startad av ollkli, 27 maj 2015.
  1. ollkli
    ollkli Y-Wing pilot
    Luleå
    Saxar informationen från countycomms hemsida då jag tror att dom flesta av er behärskar engelska. Klockan är i mkt god kondition. Inga nämnvärda spår av användning alls. Klocka och läderband är det som ingår, inget annat. Ursäkta dåliga mobilbilder. Kan om behov uppstår skicka nya via mail/sms.
    The Maratac™ Mid Pilot Automatic 2013 (Limited Red Crown) watch was privately contracted. The limited "Red Crown Series" was made by special request for a client and we have a few extra available with the permission to sell to our consumer clientele.
    The watch features a sterile clean dial, with no date and no branding. This watch is made to exemplify the purest form of time which provides a simplistic feel to the watch. Maratac™ has decided to use a Miyota (8245) 21 jewel movement known for its exceptional quality and accuracy. The Miyota movement provides 40 hours of power reserve when not in use. This movement is specially made by Citizen watch corporation.
    The Maratac™ Mid Pilot watch is truly a "Manly" watch at a little over 39mm wide and 60 grams. This watch is ideal for both formal and casual events and is truly built to last with a robust sapphire domed crystal.
    Watch Details:
    • Case: 316 stainless steel case cut from solid block.
    • Dial: Print dial. With super luminova C3 color.
    • Hands: With super luminova C3. Matte finishing
    • Strap: With strap
    • Movement: 8245 (Japan movt)
    • Water resistant: 10 ATM water resistant.
    • Crown: RED Screw crown same as drawing.
    • Crown tube: Screw tube
    • Shoulderless Spring Bar: Insert spring bar to case leg.
    • Case back: Two pieces of screw etching case back .
    • Glass: Sapphire crystal domed
    • Bronze movement retainer
    • Non-hacking movement
    Fits all 20mm bands ( Single and 2-piece band compatible )
    Pris: 1500:- i postens sköna gröna!
    Retur: Om ej som beskrivet, annars inte.
Sjöö Sandström Royal Straps
