Erikson Urhandel
Nya Panerai igen....
Diskussion i 'Diskussion' startad av masterkiller, 17 oktober 2012.
  1. ....nu har Panerai släppt två nya pannor, båda i 'Brown Panerai Composite case' en är 45mm och den andra 47mm, riktigt snygga och den som är 45mm skulle jag kunna ha men jag tror faktiskt att jag ändå hellre skulle ha en svart dvs PAM292....
    Panerai Radiomir Black Seal Composite PAM 505
    [​IMG]
    Movement: Automatic mechanical, Panerai P.9000 calibre, executed entirely by Panerai, 133⁄4 lignes, 7.9 mm thick, 28 jewels, Glucydur® balance, 28,800 alternations/hour. Incabloc® anti-shock device. Power reserve 3 days, two barrels. 197 components.
    Functions: Hours, minutes, small seconds, date.
    Case: Diameter 45 mm, brown Panerai Composite with removable wire loop strap attachments (patented). Screw-down winding crown personalised OP.
    Bezel: Brown Panerai Composite, integrated into the case.
    Back: See-through burnished sapphire crystal.
    Dial: Brown with luminous Arabic numerals and hour markers. Date at 3 o’clock, seconds at 9 o’clock.
    Crystal: Sapphire, formed of corundum, 1.9 mm thick. Anti-reflective coating.
    Water- resistance: 10 bar (~100 metres). Strap: PANERAI personalised leather strap and
    large-size brown Panerai Composite buckle. Reference: PAM00505.
    Panerai Radiomir Composite PAM 504
    [​IMG]
    Movement: Hand-wound mechanical, Panerai P.3000 calibre, executed entirely by Panerai, 161⁄2 lignes, 5.3 mm thick, 21 jewels, Glucydur® balance, 21,600 alternations/hour. Incabloc® anti-shock device. Power reserve 3 days, two barrels. 160 components.
    Functions: Hours, minutes, small seconds.
    Case: Diameter 47 mm, brown Panerai Composite with removable wire loop strap attachments (patented). Screw-down winding crown personalised OP.
    Back: See-through burnished sapphire crystal. Dial: Brown with luminous Arabic numerals and
    hour markers.
    large-size brown Panerai Composite buckle. Reference: PAM00504.
    Molle gillar detta.
  2. Spencer
    Spencer Darth Vader Admin
    Lite Glycine över det där att koka soppa på en spik..
  3. David
    David Bödeln
    Har de släppt nån Luminor i Composite? Vad är det för material?
  4. Som vanligt har du har fått det om bakfoten Spence, gör hemläxan :)
  5. Ja, PAM386 släpptes 2010 tror jag
    [​IMG]
    Sedan släppte dom även en annan brun Radiomir PAM339...
  6. David
    David Bödeln
    Ah, aldrig sett 386:an irl, trodde att den var svart/grå.
  7. Spencer
    Du är en så kallad "småpåve" Master..
