Orient M-Force Beast
Diskussion i 'Diskussion' startad av 80talisten, 19 september 2012.
  1. 80talisten
    80talisten I wish a could afford a real gold Rolex!
    Eskilstuna
    Källa: Arizona fine time.
    Orient M-Force Beast Automatic SEL06001B
    Orient Watch Co., Ltd.’ s M-FORCE watch features a newly developed mechanical movement. It is an authentic sports watch first released in 1997. As the name “M-FORCE” (short for “mechanical force”) suggests, it is a mechanical watch expressing “forcefulness” and has been widely acclaimed since its
    initial release. After an interval of about nine years, Orient is now releasing a new M-FORCE, as an authentic diver’s watch that inherits the concept of its predecessors. The M-FORCE is an authentic diver’s watch that features a smart and rugged design, water resistance to 200 meters for use in scuba diving, shock absorption enabled by a special structure, and ISO compliance. While it is an authentic diver’s watch, the M-FORCE also features superb design and high functionality, making it ideal for daily use, too.
    Watch Details:
    ISO certified | water resistant 200m | power reserve indicator | Sapphire Crystal | Hackable & Hand Winding with Automatic Winding System
    Men / Women: Men
    Power Reserve:40-Hour Power Reserve Indicator
    Crystal: Sapphire Crystal
    Movement: ORIENT caliber 40N5A Made in Japan. Self-winding & Hand-winding movement (Second Hand halt mechanism)
    Clasp: Fold-over with Double Push Button Safety
    Crown: Screwed-down
    Water Resistance :200m (Certificated by ISO 6425 diver’ s watches, ISO 764 antimagnetic watches and ISO 1413 shock-resistant watches
    Case Material: Stainless Steel
    Case Diameter: 47.00mm
    Case Thickness: 13.30mm
    Dial Color: Black
    Bezel Material: Stainless Steel
    Bezel Function: 60 Click Unidiretional Bezel
    Calendar: Date
    Band Material: Stainless Steel
    Warranty Type: 1 year international guarantee
    Retailprice: 795 dollar
    [​IMG]
    [​IMG]
    Relativt ny modell från Orient. Ärligt talat vet jag knappt själv vad jag ska säga. Mycket annorlundare design som jag faktist finner ganska tilltalande ändå. Lite som ett äktenskap mellan Seiko Emperor Tuna och Omega Ploprof.
  2. Denke
    Denke Admin Admin
    Stockholm
    Kollar och kollar på bilderna (erkänner att jag inte läst hela specen). Tänker att det är coolt med lefty, sen vet jag inte. Är det något, bortsett från det som gör den så speciell?
  3. 80talisten
    Eskilstuna
    Vad jag vet så är det ett ganska bra glapp mellan Orients mer påkostade 300m dykare och deras enkla billiga diver's så denna ska väl vara något mitt emellan. Sen tror jag den ska vara ganska chockresistent och antimagnetisk. Men jag finner designen som det mera intressanta. Fast nått som jag stör mig på med Orient är att dom envisas med dessa stora kraftreservmätare på många av deras automatare. Annars är det väldigt fina klockor för priset
  4. yonsson
    yonsson Kikuchiyo Kobra Kai
    GBG
    Gillar verkligen Orient som märke, då de har en hel del coola modeller, men denna är icke för mig.
    Kronan till vänster -Jag har klockan på höger arm
    Case Diameter: 47.00mm :shock:
