Fan vilken härligt ärlig och "rakt på" recension. Välskrivet och även kul med fakejämförelsen!
Topp!
Topp!
Steely character – Within the Breitling philosophy, the conception of a chronograph is governed by four essential criteria: sturdiness, functionality, precision and aesthetic sophistication. The Avenger Skyland is a perfect illustration of this approach. Based on the solid Avenger "platform" and reflecting all its attributes, its rugged construction includes a screw-locked crown protected by substantial crown guards, pushpiece reinforcements screwed into steel as well as a thick glareproof sapphire crystal. The result is a case that is particular shockproof and water-resistant to 1,000 feet (300 meters/30 bars). The Avenger Skyland is also distinguished by its user-friendliness that not only guarantees excellent wearer comfort but also smooth handling of the crown and non-slip pushpieces. Meanwhile, the larger hands facilitate reading off the time in any conditions. Despite its top-flight performance, the most eye-catching feature of the Avenger Skyland is doubtless its unusual aesthetic appeal. The sophisticated lines are accentuated by the high-tech look of its dial with "stencil" numeral sporting an original design. The Avenger Skyland also comes in a special version made from a blackened steel material achieved by an ultra-resistant carbon-based treatment: a limited series nicknamed "Blacksteel". - Breitling Chronolog
(Tack Tobbe-i-Etuna)
Då så, var börjar jag. Denna klocka är "the klocka". Den satte igång vansinnet. Även om jag inte var alls lika aktiv på nätet mm då, så startade ändå intresset för klockor. Jag glömmer aldrig när min vän John, som själv hade en Breitling, hjälpte mig i letandet och slog upp sidan med Avenger Skylands i Chonologen. Det var en varm dag, vi satt ute på en av barackgatorna på Camp Victoria i Kosovo. Jag bestämde mig och den blev min följeslagare i militärtjänstgöring både hemma och utomlands och den har aldrig svikit mig.
Ni kommer se battle scars på bilderna. Den har varit med i Kosovo, Afghanistan och Mali. Den har suttit på armen under överlevnadsövningar och isvaksbad. Den har bytt pipa på kulsprutor och dyngat iväg pansarspräng med granatgevär. Den väger säkert ett par gram mindre nu än när jag köpte den på grund av alla jäkla dings. Ser nästan ut som man hyvlat med en osthyvel på sina ställen.
En specifikationsintroduktion
Tillverkare: Breitling
Modellnamn: Avenger Skyland (produktion mellan 2007-2009)
Referens: a13380
Listpris: Kommer ej ihåg exakt men ca 34000kr
Material: Stål på boett och länk, Safirglas med AR på både insida och utsida
Urverk: Breitling 13, COSC (basen är ETA Valjoux 7750)
Mått: Boett: 44,5mm, Glasyta: 33mm, Bezel: 6mm, Tjocklek: 17mm, Lugg-Lugg: 54mm
WR: 300m
Vikt: Head only: 143 gram, På Professional II länken: 225 gram
Tankar om
Boett: Det är en stor och tung boett som inte är för alla. Den bärs inte bra på tunna band såsom nato då den blir väldigt topptung och det ser allmänt kass ut. Boetten är tjock och ger ett tufft intryck trots att det bara är bezeln som är borstad. Har riktigt feta kronskydd som verkligen skyddar kronan. Gillar att kronskydden har en fasning som skapar två nivåer på dem. Luggarna (22mm) är korta och rejält böjda för att passa handleden. Detta är inte en snygg feature men det gör att klockan sitter mycket bra på armen trots sin höjd. Man måste också passa sig för zulu-band som inte kommer in mellan bandstift och boett då avståndet är väldigt tajt. Kronografpushersen är härligt knottriga upptill (för vems njutning?)
Urtavla: Det finns ingen svart som är så fin som Breitlings svarta! Urtavlan är välbalanserad och har ett fint djup och många detaljer. En detalj som verkligen sticker ut är den läckert röda texten "AUTOMATIC". Har dock ej samma röda ton som kronografsekundvisaren. Trist... Sub dials klockan 12, 6 och 9. Dessa har alla 3, tunna tunna fasningar på vänsterhalvan av respektive tavla. De är också nedsänkta något och inramade av en skinande ring som ger fint liv till tavlans helhet. Datum som är snyggt inramat av en vit tunn linje klockan 3. Urtavlan är utrustad med en vanlig 100-dels skala för att enkelt dela upp en minut i hundradelar.
Visare: Inte mycket att orda om. Är väl avvägda i längd (minut passar perfekt mot de korta indexmarkeringarna) men aningen trista.
Lume: Har ganska lite lume men funkar tillräckligt bra för det militära och det borgar ju för något. Hade inte varit bra att toklysa om armen när man smyger runt i läskiga terrängen...
Boettbaksida: Framgår att det är en COSC kronograf och att den tål 300m. Mitten pryds av en borstad yta med det bevingade "B" i mitten. Inget avancerat men den gedigna känslan hänger i.
Krona: Kronan är stor men göms snyggt mellan kronskydden. Den är räfflad runtom och tickar härligt när man skruvar ut den till första läget. 3 lägen – uppdrag, datum, tid.
Länk: Breitling gör så jäkla gedigna, sköna och robusta länkar så här finns verkligen inget att klaga på. Min är på professional II som är allt ovan nämnda. I övrigt kan jag nämna att den sitter störtbra på ammo straps (mina från Anders W) men inte alls bra på Breitlings original mesh.
Bandbyte: Lättare att ta av än att sätta på då den har solida ändlänkar som är lite trixiga ibland (speciellt om man har bråttom). Inte konstigare än på någon annan klocka.
Lås: Ett viklås som riktigt ordentligt och inte rackigt öht. Har 4 hål för micro-justering. Snygga fasningar för bygeln.
Övrigt: Inte mycket lull lull på denna bratten dock fylld av en massa spännande och väl genomarbetade detaljer. En klocka var storlek jag svurit över många gånger när jag fastnat eller slagit i metall och annat. När den var min enda finare klocka så hade jag den till allt. Det har jag inte längre då av alla självklara anledningar. OM man tänker köra OWG och vill ha denna så bör man tänka på att den ibland kärvar att få plats med under skjortan. Vill också bekänna att jag ibland håller klockan i handen, svingar till lite och sätter den sedan till örat. Då får man höra ett vackert surr från urverket. Låter knäppt men jag är nog inte ensam om detta.
Summering: Snygg och ha som "vanlig" klocka och skitgrym om man vill ha den som beater. Den har tålt hur mycket styrk som helst och det var därför jag köpte just denna modell. Enda minuset för min egen del är tjockleken annars har jag inget att klaga på. Sen har jag så mycket minnen och känslor kopplat till just denna klocka så nå vidare objektiv är jag nog inte
Frågor jag fått i " Kommande recension av Avenger Skyland - Vad vill ni veta?"
Jämförelse mot andra klockor (Icaras Mr_Jonas snoozarn) : Kommer bilder längre ned
Vikt (Denke ) är med redan.
Känner man sig framgångsrik med den på armen (skallagrimson): JA!
Jobbar du som dörrvakt (puonti)?: Nej
Är det verkligen sant det JoberMan påstår (Mr_Jonas)?: Klart det är sant! Dock är det lite tunnare på polotröjefronten nu för tiden.
Allmänt najsiga shots (jbbs V hedbrg Jonulf):
Jämförelser med en Omega SMP
FEJK!!!
Nu tänkte jag även göra en jämförelse med en fejkad Avenger Skyland. Ge lite "tells". I och med att det är olika aktörer som gör fejk så ser det lite olika ut från respektive tillverkare. Jag har jämfört med en H-Factory v4. Kommer alltså en hel del fejkbilder nu!
- Tvåan i datumet har för lång "tapp".
- Inget mellanrum mellan lumeplupp kl 3 och den målade indexeringen kl 3.
- De första långa målade indexlinjerna intill lumepluppen kl 3 är för långa. På äkta slutar de innan upphöjningen som är runt datumet (lumepluppen också inne och petar på upphöjningen på den falska).
- Ytterlinjen på vingarna är tjocka hela vägen runt. På äkta är den övre linjen lite tjockare än resterande ytterlinje.
- "R" i BREITLING saknar "tapp" på vänstra benets nedre del. Överlag inte lika skarpa linjer i texten. G ett bra exempel.
- Ankarets 3 spetsar nedtill är för oskarpa i kanterna.
- "Niten" som håller fast visarna är omålad på fejkbilden. Är målad vit på äkta samt inte så kasst "avklippt" utan mer som en riktig platt nit.
- Fyrkanten på kronografsekundvisaren är ojämn i kanterna
- Långa målade indexet direkt vänster om 8 resp 9 i 80 och 90 sitter för långt ifrån på fejk. 9ans nedre tapp är för kort på fejk också...
- 8:ans övre del som är avskuret är inte lika detaljrikt som på äkta
- Fel font på text, se "G" tex. PÅ fejk sluttar det utan en rak del längst till höger
- Där lilla och stora cirkeln möts i mitten på B så är det inget mellanrum på den fejkade. Det är det på den äkta. Finare konturer på äkta.
Äkta nedan...!!!
- Röda texten för högt upp i förhållande till sub dial kl 6
Ny fejkbild...
Äkta nedan...!!!
- Lilla "B" på vridringens ovankant (typ halv 12) ser annorlunda ut. Inte lika fint "utskuret".
Övrigt:
Målade index direkt under siffrorna 10 – 100 är för boxiga på fejk och mer rektangulära på äkta.
Lume dots ej jämna över hela tavlan
Frågor?
Tack! På en del modeller är det så. Jag gillar inte heller alla såklart. Som med alla märken. Avenger-serien är dock en favorit tillsammans med Transocean-serienGrym recension. Däremot är jag inte helt inne på Breitling, det är lite väl mycket som händer för mig på de flesta jag ser. Men snygg, ser robust och praktisk ut.
Kul att du gillade läsningen. Trist att du saknar din gamla men det kommer nya! Men vissa är svåra att komma över.Riktigt trevlig läsning. Min första brille var just en skyland avenger med blå urtavla då. Kul att du skrev den biten med sentimentalt värde då jag sålde min och har saknat den sedan dess. Kan givetvis köpa en likadan men de blir aldrig samma sak. Jag nästan dör lite inombords när jag får en ding eller liknande på någon av mina klockor så när jag ser att folk använder sina klockor så som klockorna är menade att användas blir jag alltid lika fascinerad. Så som OP med sin skyland, eller en gubbe på ett jobb jag va på som stod och armerade betong fundament med en datejust på handleden eller min bror som använder sin explorer i vått och torrt.
Bruksklockor ska brukas - och det hårt!!!
Kul, det är en av mina absoluta favoriter så du har nog mycket nöje att se framemot. Grattis till ett bra köpGrym recension! Köpte just en likadan och är än så länge supernöjd!
Den är riktigt bra. Använder den riktigt mycket fortfarandePrecis som du spanade jag in denna som min första klocka för 9 år sedan! Och när jag väl bestämde mig kom avenger 2 och den va inte alls lika magisk! Det var just denna med vita visare och siffror samt svart tavla som gjorde mig tokig i klockor! Sedan dess har jag inte ägt denna och nu var det dags. Det är kärlek igen vid första ögonkastet precis som när jag testade den på armen i butik
