Här kommer mer info om den
Hitta denna sida
http://watcharama.com/sinn-356-review/
Jag tycker den funkar kanon, måste dock försöka kika på en 358a på 42mm innan jag kan slappna av helt. Länken är dock helt i värlsklass , och jag hade för länge sen en Sinn U2 som hade samma länk, så då var köpet av denna lättare... Visst läder band kunde va kul att testa också...
Köpt på ebay.de, begagnad ch ca 4-7år gammal troligen, inte mycket använd, för den är i bra skick.
Så här står det om den:
This is one of the best selling Sinn instrument chronograph watches. For convenience, the watch comes with a 42-hour power reserve. The movement is protected from magnetic influences and is shock-resistant. Additional functionalities include luminous hands and numerals, day and date window at the 3 o'clock mark, complete chronograph functions, subsidiary seconds and shock-resistant acrylic glass.
Based on a streamlined version of the 256 pilot's chronograph developed for the Japanese market, our 356 series was created in 1996 with the characteristic FLIEGER [PILOT] logo on the matte black dial. With a case diameter of 38.5 mm, it is somewhat smaller, but even more successful in design.
This classically elegant chronograph captures your attention with its clean, esthetic style. There is nothing to distract from the essentials. Everything is designed to ensure accurate reading of the various times. The hour, minute and centrally positioned second hand are skeletonized and coated with special long-lasting, luminous paint, as are the large, clearly readable Arabic numerals. The high-quality seal of the crown, push-pieces, back and acrylic glass makes the 356 PILOT water-resistant in accordance with DIN 8310 and pressure-resistant to 10 bar (= 100 m water depth).
Mechanical Movement
SW 500
Self-winding mechanism
25 bearing jewels
28,800 semi-oscillations per hour
Seconds stop function
Shock resistant as per DIN 8308
Anti-magnetic as per DIN 8309
Case
Case made of stainless steel, bead-blasted
Acrylic glass in front
Case back screw-fastened
Crown screwable
Water-resistant as per DIN 8310
Pressure-resistant up to 10 bar (= 100 m water depth)
Low pressure resistant
Functions
Hours, minutes, subsidiary seconds
Date display
Day of the week display
Chronograph
Dimensions and Weight
Case diameter: 38,5 mm
Band lug width: 20 mm
Case thickness: 15,5 mm
Weight without strap: 71 gramme
Dial and Hands
Matte black dial
Numbers coated with luminescent colour
Hour, minute and stopwatch second hand coated with luminescent colour
