.......den ser rätt trevlig ut. Dock är vetskapen om Tudors serienr/årtal inte lika utvecklad. Att denna ska vara från -81 känns märkligt. Min har serie nr 937 och är från -80 om man ska tro listorna??
Trodde 0 brytningen kom senare. Nån som sitter på mer info?
http://www.network54.com/Forum/2076...1981+Tudor+Submariner+94010+Snowflake+No-Date
Denna lista går jag efter:
I have been working on the serial numbers of tudor in particular for tudor chronos and submariner and have published in forums in HK. Though the info consolidated is still limited so far, some of my findings are as follows :
Year Least S/N
1960 28xxxx
1961 34xxxx
1962 36xxxx
1963 39xxxx
1964 43xxxx
1965 50xxxx
1966 56xxxx
1967 59xxxx
1968 62xxxx
1969 68xxxx
1970 74xxxx
1971 75xxxx
1972 77xxxx
1973 (*) 79xxxx
1974 (*) 81xxxx
1975 (*) 83xxxx
1976 (*) 84xxxx
1977 86xxxx
1978 (*) 88xxxx
1979 (*) 90xxxx
1980 (*) 93xxxx
1981 (*) 95xxxx
1982 97xxxx
1983 (*) 99xxxx
1984 29xxx
1985 14xxxx
1986 17xxxx
1987 (*) 19xxxx
1988 21xxxx
1989 26xxxx
1990 B33xxxx
1991 (*) B36xxxx
1992 B39xxxx
1993 B50xxxx
1994 B58xxxx
1995 B59xxxx
1996 B79xxxx
1997 B85xxxx
1998 B99xxxx
1999 H13xxxx
Remarks : * is the estimated S/N due to limited info
For Tudor Chrono
Model No. Approx S/N Range
703x/0 ~ 75x,xxx to ~ 76x,xxx
71x9/0 ~ 77x,xxx to ~ 84x,xxx
94xx/0, 94xx0 ~ 87x,xxx to ~ 26x,xxx
791x0 ~ 27x,xxx to ~ B 63x,xxx
792x0, 792x0P ~ B 63x,xxx to ~ H 74x,xxx
For Tudor Sub
7922¡A7924 ~ 24x,xxx to 29x,xxx (Possible as early as 140K)
7928¡A7928/0 ~ 30,xxx to 62x,xxx
7016/0 ~ 62x,xxx to 82x,xxx (Possible as early as 570K)
7021/0 ~ 73x,xxx to 78x,xxx
9401/0¡A94010 ~ 84x,xxx to 1xx,xxx
9411/0, 94110 ~ 79x,xxx to 96x,xxx (Possible as late as 1x,xxx)
76100 ~ 70,xxx to 22x,xxx
7x090 ~ 30x,xxx to B67x,xxx
7x190 ~ B 67x,xxx to H 14x,xxx
Year Least S/N
1960 28xxxx
1961 34xxxx
1962 36xxxx
1963 39xxxx
1964 43xxxx
1965 50xxxx
1966 56xxxx
1967 59xxxx
1968 62xxxx
1969 68xxxx
1970 74xxxx
1971 75xxxx
1972 77xxxx
1973 (*) 79xxxx
1974 (*) 81xxxx
1975 (*) 83xxxx
1976 (*) 84xxxx
1977 86xxxx
1978 (*) 88xxxx
1979 (*) 90xxxx
1980 (*) 93xxxx
1981 (*) 95xxxx
1982 97xxxx
1983 (*) 99xxxx
1984 29xxx
1985 14xxxx
1986 17xxxx
1987 (*) 19xxxx
1988 21xxxx
1989 26xxxx
1990 B33xxxx
1991 (*) B36xxxx
1992 B39xxxx
1993 B50xxxx
1994 B58xxxx
1995 B59xxxx
1996 B79xxxx
1997 B85xxxx
1998 B99xxxx
1999 H13xxxx
For Tudor Chrono
For Tudor Sub
