Väldigt intressant. Vad säger du om Sinns Tegimenteringsteknik?
Back
TEGIMENT
Greatly increased scratch-resistance thanks to surface hardening
TEGIMENT Technology raises the
hardness level of the base material, e.g.
stainless steel, by a significant factor. The technology was first introduced in the 756 Duochronograph at the International Baselworld Watch and Jewellery Show in Basel in 2003, replacing the
ice hardening technique for
nickel-free watch cases first presented in 2002. Originally TEGIMENT Technology was only used on
stainless steelcases. The term is now used to refer to all materials with a hardened surface.
TEGIMENT Technology provides highly effective protection against scratches. The method is not, however, based on the application of a coating. Instead it is the surface of the material itself which is hardened by means of a special process, thereby creating a protective layer (“tegimentum” in Latin). The surface of any watch hardened using TEGIMENT Technology has a significantly greater level of protection against scratches than that afforded by the
hardness of the base material.
