- Pris
- 85000
- Returpolicy
- Om ej enligt beskrivning
- Bilder Skickat
- Ja
Förmodligen enda i Sverige tillgängliga (spekulation) Girard-Perregaux Laureato 42mm med blå tavla.
Klockan är fullset, och i det närmaste i nyskick.
Klockan är köpt i September 2018 från Fredmans Ur på Strandvägen.
Således garanti på klockan.
Ca 6 månaders väntetid på denna blå modellen.
Nypris 127 000kr.
Detta är inte din vanliga dussinprodcerade Rolex, utan en helt handbyggd skönhet med tonvis av charma.
Girard-Perregaux Laureato lanserades 1 år innan Patek Philippe Nautilus, 1975. Nautilus kom 1976!
Klockan bör upplevas i verkligheten för att förstå.
"Some may consider Girard-Perregaux Laureato to be just one of the Gerald Genta-inspired pieces, and lacks originality. On the contrary, the Laureato and other watches from the 70’s, including Genta’s, were simply following the fashion style of that years. In that sense, neither copied the other. They were all following the same trend, somewhat like the trend of re-issuing classic pieces today. Nevertheless, the GP Laureato is a magnificent all-rounder, pulling off a sporty or elegant look with ease.
-Not to forget, there is of course the Patek Philippe Nautilus. Ref. 5711. The Nautilus was released a year later after GP Laureato, in 1976."
Dan-Andrei Kluska August 25, 2017
https://deployant.com/review-girard-perregaux-laureato/
"GP Laureato GP01800-0013 is visible through the sapphire back crystal. The view reveals excellent finishes of the in-house movement
On the technical front, the GP01800 is a modern 4Hz movement with an admirable power reserve of 54 hours.
The movement is nicely decorated with perlage (circular graining), Côtes de Genève (Geneva waves), and bevelling (chamfering).
The movement is entirely made and finished in-house. From designing to producing and adjusting, everything is done on site at the Girard-Perregaux manufacture.
There are small details that make this movement not just agreeable, but beautiful. For instance, the balance wheel cock alone boasts 3 different finishes."
CASE
Material: Steel 904L --> OBS! Samma stål som Rolex!
Diameter: 42,00 mm
Height: 10,88 mm
Case-back: Sapphire crystal
Dial: Blue with "Clou de Paris" pattern
Water resistance: 10 ATM
STRAP
Size: 27,00 / 18,00 mm
Buckle: Triple folding
Buckle material: Steel 904L
MOVEMENT
Caliber: GP01800-0013
Type: Self-winding mechanical movement
Diameter: 30,00 mm (13 1/4''')
Height: 3,97 mm
Number of components: 191
Jewels: 28
Finishes: Côtes de Genève, circular graining and bevelling
Power reserve: Min. 54 hours
Länkar:
https://www.ablogtowatch.com/girard-perregaux-laureato-steel-42mm-watch-review/
YouTubelänken visar exakt samma modell:
Klockan är 42 mm i storlek, men bärs som en Datejust 41
Fler bilder på min klocka, samt kort film:
https://photos.app.goo.gl/emZXuCw6a9Zfrd7C7
Nypris 127 000kr.
CASE
Diameter: 42,00 mm
Height: 10,88 mm
STRAP
MOVEMENT
Height: 3,97 mm
Jewels: 28
Länkar:
