- Pris
- 53000
- Returpolicy
- Om ej enligt beskrivning
- Bilder Skickat
- Ja
Fullset Omega Planet Ocean GMT med Omegas nya Master Chronometer verk 8906 med 60 h power reserv och antimagnetiskt till 15000 Gauss! Nära nyskick på klockan.
Detta är den mindre Planet Ocean modellen (43,5 mm) och bärs som en 42 mm då "lug to lug" är relativt kort.
Bi-Keramisk ring (svart och vit) samt svart keramisk urtavla med vitguld index med bra Luminova.
GMT funktion med individualt flyttbar timvisare (samma som Rolex GMT)
Svensksåld 2018 från Franks Ur i Stockholm.
Nypris: 73 700 kr
Klockan är full set med låda samt Master Chronometer certifikat
Mer info:
Skick:
4,8 / 5 (nära nyskick)
Chronometer
Label given to a watch which has undergone precision tests and received a certificate from an official body (COSC).
Date
The day of the month, displayed in a window on a watch dial typically at the 3 o'clock or 6 o'clock position.
Anti-magnetic
The movement is unaffected by exposure to strong magnetic fields, even those greater than 1.5 tesla (15,000 gauss).
Helium escape valve
Decompression system which allows helium to escape from inside the watch when the watch is worn for professional use in pressure chambers. (Long-term underwater work, crude oil exploration, etc.)
Screw-in crown
Self-locking crown, screwed into the tube of the case, used for highly water resistant divers' watches.
Bi-directional rotating bezel
A bezel which can be turned clockwise or anti-clockwise. Rotating bezels can be used to time events, measure elapsed times, or read second or third time zones.
Transparent case back
A transparent case back - frequently made of sapphire - makes it possible to see the movement inside the watch.
https://www.omegawatches.com/watch-...master-chronometer-gmt-43-5-mm-21530442201001
Nypris: 73 700 kr
Mer info:
Skick:
Chronometer
Date
Anti-magnetic
Helium escape valve
Screw-in crown
