Avslutad Omega Seamaster Chronograph CK2907 "Seemaster" 1956, prisbump 19.500:-
NiklasArvid
Mon Mothma
3dar om fel i beskrivning
Omega Seamaster CK2907 in the most attractive case and well proportioned dial. 34mm excl crown, 41 lug to lug. 17.5mm lugs.
This one is from the small batch of 1956 with Seamaster misspelled on the caseback "Seemaster". There are a couple other identical ones found within a very narrow serial number range.
Plus:
Clean original 321 movement with original balance and regulator
Keeps good time
Chronograph works fine and resets to zero.
Attractiva patina dial
Case in good condition
Minus
Replaced subdial hand
Hour counter creep
Caseback does not sit tightly. It does not come off but can rotate slightly since there is at present no gasket, maybe the right gasket is needed and will solve the issue?
Located in Stockholm.
SEK 19.500:-
