- Pris
- 2600
- Returpolicy
- Om något avviker från beskrivnnngen
- Bilder Skickat
- Ja
Samlar på mig klockor jag gillar men någonstans måste de också brukas för att ha ett existens berättigande..
Båda i mycket bra skick, minimala spår avvanvändning..
1. Precista PRS-10, något år gammal.
Pris: 2700:-
The improvements over the original G10s are:
- Movement upgraded to Ronda 715 Li with 10- year battery life
- Crown is now a screw-down crown
- Caseback is now a screw back
- Crystal is now double-dome sapphire (box crystal)
- Lug spacing now 20mm (was 19mm) to give a greater choice of straps
- Luminous is now Super Luminova X1 C3
ISL-05 (”fabriks trimmad Skx013) några månader gammal.
Pris: 3500:-
Pris: 2700:-
- 316L stainless steel, bead blasted
- Diameter 39.1mm across including crown, 37.1mm top to bottom
- Lug to lug height 42mm
- Thickness to top of crystal 11.2mm
- Lug spacing 20mm
- Anti-magnetic 4800 A/m
- Water resistance 100 metres
- Weight 49 grammes without strap
- Screw back, drilled lugs
- Semi-matte black
- Hour dots & triangle at Super Luminova X1 C3
- Date at 3 o'clock position
- Polished silvered, luminous filled
- Luminous: SuperLuminova C3
- Hi-dome sapphire (box crystal)
- Ronda 715Li with 10-year battery life (CR2016 Battery)
Pris: 3500:-
- Movement: NH36 Automatic (self-winding, hand wind, hacks)
- Case: Stainless steel, 38mm x 13mm thick. 44.5mm tip to tip
- Back: Engraved screw-in back
- Crystal: Anti-reflective (blue hue) flat sapphire
- Band: Bracelet with all solid links, Push-Button Deployant Clasp, 20mm.
- Water Resistant: 200 meters
- NOTE: The Islander dive and dual-time watch is compatible with aftermarket parts available at Island Watch (and elsewhere) for the SKX013 models, such as crystals, bezels, inserts, chapter rings, dials, hands, bracelets, etc.
