- Pris
- 7900
- Returpolicy
- Ja, om avtalad innan köp
- Bilder Skickat
- Ja
Ref: 2239M-ST-00609
Knappt använd och i nära nyskick!
Fortfarande en del plast kvar på baksidan och på spännet.
Snor lite info från:
www.seriouswatches.com
8900 7900 inkl rek frakt
![www.seriouswatches.com](/proxy.php?image=http%3A%2F%2Fwww.seriouswatches.com%2Fcdn%2Fshop%2Fproducts%2F2239M-ST-00609_600x.jpg%3Fv%3D1552819400&hash=851f806ab4b0a419966629969c93d320&return_error=1)
Raymond Weil Maestro Moon Phase 2239M-ST-00609
The Raymond Weil Maestro Moon Phase 2239M-ST-00609 is an incredibly stylish Swiss Made watch. As the name implies, the watch has a moon phase complication. At 6 o'clock you'll see an aperture in the dial which shows the actual position of the moon (so it's not a day/night indicator). Alongside...
![www.seriouswatches.com](https://www.seriouswatches.com/cdn/shop/files/streamdeck_key_Monogram_square_32x32_2_32x32.png?v=1613734552)
Specifications | |
Movement | Mechanical |
Calibre | Raymond Weil Cal. RW4280 |
Hacking | Yes |
Power reserve | 38 hours |
Hand winding | Yes |
Automatic | Yes |
Glass | Sapphire glass |
Date | Yes |
Width (without crown) | 40mm |
Thickness | 9.8mm |
Lugs | 20mm |
Water resistance | 50m |
Dial | Grey |
Case material | Steel |
Band material | Steel |
Caseback | Display |
Country of manufacture | Switzerland |
