wharfedale
Breitling
Hej! Här kommer en kortare recension på senaste inköpet Casio AE-1200WHD-1AVEF
Specifikation:
LED light - A light-emitting diode (LED) is used to illuminate the watch face.
4 time zones display - Local times can be called up quickly and easily for four different time zones.
World time function - Displays the current time in major cities and specific areas around the world.
Stopwatch function - 1/100 sec. - 24 hours - Elapsed time, split time and final time are measured with 1/100-sec accuracy. The watch can measure times of up to 24 hours.
Timer - 1/1 sec. - 24 hours - For fans of precision: the countdown timers help you to remember specific or recurring events by giving off an audible signal at a preset time. They The time can be set to the nearest second and up to 24 hours in advance.
5 daily alarms - The daily alarm reminds you about recurring events with an acoustic signal at the time you have set. This model has 5 independent alarms for flexible reminders of important appointments.
Button tones on/off - The button tones for using the mode button can be turned off. This means that the watch no longer beeps when switching from one function to another. Preset alarm or countdown timers remain active when the button tones are deactivated.
Automatic calendar - Once set, the automatic calendar always displays the correct date.
12/24-hour timekeeping - Times can be displayed in either a 12-hour or 24-hour format.
Resin case
Stainless steel band - Tough, durable and elegant: The stainless steel wrist strap gives your watch that classic feel.
Safety Catch - Always reliable: This watch has a particularly secure safety catch, which helps prevent the strap from opening by mistake.
Long Battery Life - 10 years, 1 battery. Newly developed electronics ensure significantly lower energy consumption.
Water resistance classification (10 bar) - Perfect for swimming and snorkelling: the watch is water resistant to 10 bar according to ISO 22810.
Dimensions (H x W x D) - 45,0mm x 42,1mm x 12,5mm
Weight - approx. 50,0 g
Den kanske mest anmärkningsvärda funktionen torde vara "Automatic calendar" där man enligt tillverkaren endast behöver ställa in datumet en gång för att sedan alltid har rätt datum i klockan. Spektakulärt!
Mina intryck efter ett par dagars användning:
Det första som slog mig när jag fick klockan i handen är hur plastig klockan kändes. Jag får ingen kvalitétskänsla öht tyvärr. Man kanske inte kan begära mer av en klocka som väger in på runt 50 gram iof...
Boetten är i mitt tycke gjord av plast, knapparna är däremot gjorda av stål. Armbandet även det i stål, men spännet är riktigt uselt. Svårt att öppna/stänga.
"Glaset" är redan repat, trots att jag sitter vid ett skrivbord utan några äventyrliga upptåg.
Jag var på jakt efter en rektangulär klocka, så valet föll på denna. Ångrar jag köpet? Både ja och nej... Jag hade nog bara lite för höga förväntningar helt enkelt. Klockan visar ju trots allt tiden, och har en kalender som alltid visar rätt datum.
Mer info finns på Casio's hemsida:
https://www.casio-europe.com/euro/products/watches/collection/ae-1200whd-1avef
Specifikation:
Resin case
