- Pris
- 3000
- Returpolicy
- Ja, om ej fungerande.
- Bilder Skickat
- Ja
”This is the Tactico ANKO, an homage to the legendary Seiko 6159-7001, made by the Spanish microbrand Crepas.”
Dimensions:
• Bezel diameter: 42mm
• Case diameter: 43,50mm
• Total thickness: 15,25mm
• Thickness without sapphire crystal: 14mm
• Length: 48mm
• Crystal diameter: 31mm
• Crystal thickness: 3mm
• Strap wide: 22mm
• Crown diameter: 7mm
• Bezel thickness: 4mm
Meterials:
• Case, crown, case back cover and bezel made of 316L stainless steel. Brushed and polished finished
• Bezel inlay and main crystal made of sapphire
• Viton and tefzel gaskets
• Rubber for straps and nylon for NATO strap
• BGW9 Superluminova for dial and hands
• Dark yellow Superluminova for bezel pearl
Features:
• Japan TMI SII NE15 movement (SEIKO)
• Applied indexes and date window frame
• ANKO name applied over dial
• Dark grey soleil effect dial
• Crown and case back cover screwed down
• 1000 meters water resistant
• Double domed sapphire crystal with AR on inner side
• Limited Edition 400pcs
Kit:
• Watch
• Bonetto Cinturini rubber strap
• Custom NATO strap
• Bars remove tool
• Cleaning cloth
• Warranty card
• Booklet
Detta ex är nr 96 av 400 och kommer med original nato, original gummi och extra tvåtonslänk från Geckota (Waffle på bilderna ingår ej.)
Kan skickas i Seikobox.
Noteras bör att det finns repor på bandhornen efter slarviga bandbyten!
3000kr inkl Postens ”skicka lätt” frakt.
Betalning med Swish
Dimensions:
• Length: 48mm
• Strap wide: 22mm
Meterials:
Features:
Kit:
• Watch
• Custom NATO strap
• Bars remove tool
• Cleaning cloth
• Warranty card
• Booklet
Betalning med Swish
