Google is your friend ...:
The watch winder series – Evolution - from the long established British manufacturer Rapport London is suitable for one automatic on each module. Through its novel oscillation technique, this watch winder provides for a constant spring tension in installed timepiece. Due to its square design, low overall height and optional battery operation, the individual modules are ideal for use in a vault. Using the optionally available wooden boxes, in which, depending on the type two or four individual Evo modules can be placed, you will be able to operate up to four modules on only one power supply. The perfected clasp system, which is suitable for both steel and leather bracelets, can be easily adjusted to the extent required by the bracelet.
On first being taken into operation, three short operational intervals occur to ensure that the watch is correctly positioned in the watch winder. This is followed by an eight-minute operation to supply the watch with basic tension before the watch winder switches into the selected program.
a) Every operational phase of one-minute is followed by a pause of 59 minutes
b) Every operational phase of one-minute is followed by a pause of 29 minutes
c) Every operational phase of one-minute is followed by a pause of 14 minutes
Med andra ord hur länge den ska vila mellan varje cykel.
