Erikson Urhandel
Ny Panerai släppt...
Diskussion i 'Diskussion' startad av masterkiller, 13 september 2012.
  1. ...en Panerai Submersible, PAM00389....
    http://www.panerai.com/s_page.xpd?id_lingua=2&id_sezione=16&id_prodotto=11614&id_categoria=9002
    LUMINOR SUBMERSIBLE 1950 AMAGNETIC 3 DAYS AUTOMATIC TITANIO - 47MM
    The creative energy of Officine Panerais Workshop of Ideas is demonstrated in the Luminor
    Submersible 1950 Amagnetic 3 Days Automatic Titanio, the new model which is a
    novel synthesis of the strict respect for traditional values and authenticity of the Panerai brand,
    and the continuous search for technically advanced solutions.
    Remarkable resistance to magnetic fields
    For Panerai, innovation is above all about functionality, and in the Luminor Submersible 1950
    Amagnetic 3 Days Automatic Titanio it is seen in its special case construction which ensures a
    remarkable degree of resistance to magnetic fields: 40,000 A/m (ampere per metre), a limit more
    than eight times greater than the value specified by the international standards of the Normes
    de lIndustrie Horlogère Suisse (NIHS 90-10). Such a high limit is achieved by the use of a special
    internal case made of soft iron of the highest purity, which encloses and isolates the movement,
    forming a Faraday cage that diverts the flow of magnetic fields. The soft iron case is immediately
    beneath the dial, which is made of the same material.
    This case structure is useful not only in extreme environmental situations but also in daily life,
    in that watches are often exposed to magnetic fields generated by electric charges and
    currents emanating from objects in common use, such as household appliances, computers
    2 and cell phones. Such magnetic fields can noticeably alter the rate of the watch and even stop
    the movement: a possibility that is virtually non-existent in the new Luminor Submersible 1950
    New ceramic and titanium bezel
    The soft iron internal case of the Luminor Submersible 1950 Amagnetic 3 Days Automatic Titanio
    is contained within a classic Luminor Submersible case of brushed titanium, fitted with the lever
    bridge which locks the winding crown and thus helps in achieving water-resistance to a depth
    of 300 metres. The design of the watch includes a feature which is completely new in Panerai
    watches: applied to the rotating titanium bezel, inspired by that of the models made by Panerai
    for the Egyptian Navy in the 1950s, is a disc of opaque black ceramic, on which the linear and
    dot-shaped titanium markers are fixed. The bezel rotates only in a clockwise direction, to prevent
    accidental movement interfering with the measurement of the time of the dive.
    Movement:
    Automatic mechanical, Panerai P.9000 calibre, executed entirely by Panerai, 13¾ lignes, 7.9 mm thick, 28 jewels, Glucydur® balance, 28,800 alternations/hour.
    Incabloc® anti-shock device. Power reserve 3 days, two barrels. 197 components.
    Functions:
    Hours, minutes, small seconds, date, calculation of immersion time.
    Case:
    Diameter 47 mm, brushed titanium.
    Bezel:
    Anti-clockwise unidirectional rotating bezel in ceramic and brushed titanium with polished edges, graduated scale for calculating the time of immersion and ratchet click at minute intervals.
    Back:
    Screw, titanium.
    Device protecting the crown:
    (protected as a trademark) Brushed titanium.
    Dial:
    Black with applied luminous hour markers.
    Date at 3 oclock, seconds at 9 oclock.
    Crystal: Sapphire, formed of corundum, 3.2 mm thick. Anti-reflective coating.
    Water- resistance:
    30 bar (~ 300 metres).
    Strap:
    PANERAI personalised rubber strap and large-size brushed titanium buckle. Supplied with a second interchangeable strap, a tool to change the strap and a steel screwdriver.
    Available this October, priced at 8900 Euro
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  2. 80talisten
    80talisten I wish a could afford a real gold Rolex!
    Eskilstuna
    Den där modellen var riktigt snygg! jag gillar bezelen på den.
  3. Aquaracer2
    Aquaracer2 Salacious B. Crumb
    Skärgården
    Jag gillade den med, men 47mm oavsett dinka är som bådat för slagsida på mig :p
  4. daviden
    daviden Admin Admin
    Malmö
    Jag har SVÅRT för att erkänna det här, men den där svarta bezeln ...på en Paneri. Jag gillar't.
  5. Eric Jajjamensan P
    Eric Jajjamensan P Sektledare
    Spexeryd
    Masterkiller! Hur mycket bula i brallan har du nu? Som klocka betraktad rejält lyft för deras Sub.
  6. Aurum
    Aurum R6-H5
    Nej, svart vridring var inte så lyckat.
  7. Vet faktiskt inte om jag gillar det eller inte....
  8. Denke
    Denke Admin Admin
    Stockholm
    Tycker inte heller att det kändes som en hit. Fast jag iofs inte så fötjust i Submersiblen alls....
  9. Ministern
    Ministern Admin Admin
    Jag tycker klart det är snyggaste Panna Subben.
  10. Hoppas man kan få klämma på den live nån gång, men 47mm kräver sin handled...
  11. P-A
    P-A Sir Spamalot
    Hälsingland
    Re: Sv: Ny Panerai släppt...
    Med tanke på all öl som svingas på alla gtg så borde folk här ha grova handleder :)
    skickat med telefonen.
  12. Porsan
    Porsan Capitão de mar e guerra
    De sju haven...
    Tycker den ser riktigt fet ut, snyggaste subben från Panerai. Trodde habegäret för Panerai släppt, men som sagt 47mm är lite i största laget.
  13. Hittade lite nyare och riktigt bra bilder på Paneristi, ser fet ut och 47mm ÄR stort..
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  14. Preklin
    Preklin Rebel soldier
    Snygg men på tok för stor.
  15. Jockinho
    Jockinho Tie Fighter pilot
    Motala
    Udda men jag gillar mycket, passar bra med svart bezel också. Och 47mm titanklump klarar du väll bära upp Masterkiller ;)
  16. David
    David Bödeln
    Riktigt cool, den där är den första Submersiblen jag tyckt om. Dock hade jag nog hellre sett den i 44mm.
