Kaplans Auktioner Erikson Urhandel
    Stäng notis
Avslutad Nyheter !! Sharkmesh och Travel Case.
Diskussion i 'Handla - Säljes, bytes' startad av Royal Straps, 23 oktober 2014.
  1. Royal Straps
    Royal Straps Företag Forumsponsor
    Hej Alla,
    Lite nyheter från Zuludiver i England som vi nu sammarbetar med.
    Travel Case i Leatherette med grå sömmar ( strap invändigt svarta ej som bild ) 400kr
    Keep your precious watch safe with this high quality zip-up watch travel case. Specially designed for ZULUDIVER, this case is made from black leatherette with grey velour lining. The box has a cut out for your watch, complete with 2 elasticated loops to keep the watch in place. The case also has a useful compartment that can be used to store additional straps, spring bar tools etc. This case is suitable for large watches up to 50mm head diameter including the crown.
    • The outer dimensions of the case are: 180mm x 85mm x 60mm tall.
    • The cut out for the watch is: 140mm from top to bottom and 50mm diameter for the watch head, 26mm for the strap and 30mm at the buckle, 15mm deep.
    • The compartment measures: 140mm x 45mm x 15mm deep.
    Now there is no excuse for keeping your watch inside a rolled up sock when travelling, why not keep is safe with one of these handy cases. Unlike some other cases of similar design this one is reassuringly solid with a good quality zip.
    Sen detta supercoola Sharkmesh i Polerat Stål 22mm endast 600kr kommer senare även i 24mm.
    This stylish and flexible "Ploprof" 316 SHARK mesh strap was inspired by the original Omega Seamaster 600m Ploprof mesh. Our mesh straps are made from 1.2 mm diameter 316L stainless steel wire for the best performance and strength of finish. Suited for a larger watch, the overall 4 mm thickness will sit comfortably on your wrist. Features innovative 'H' link details to make length adjustment possible.
    Lug width: 22 and 24 mm
    Buckle size: (22 mm and 24 mm have 22 mm wide buckle)
    Buckle type: 316L Stainless steel solid diver clasp with push button
    Thickness: 4.0 mm
    Spring bar hole diameter: 1.78 mm (spring bars are included)
    Material: 316L Stainless steel
    Max. length: 185 mm
    Min.length: 135 mm
    Net Weight: 80 gram
    Lug end style: Open type straight end
    Adjustment type: 4 Screw H links + 3 micro hole type adjustment on the clasp
    The strap is supplied with 4 "H" links, each link will change the length of the strap by 12.5 mm. Please note that the links feature a double screw head design and some care is needed when removing these.
    Tack för annonsplatsen KS och ha en bra dag alla / Mathias
