Avslutad Omega Planet Ocean 45.5mm REF: 22105000 prisbump 33 —-> 32k —-> 29k super pris
VintageJesus
Ej retur då pengarna investeras vidare
Tjena!
Säljer min grymma omega planet ocean. Uttagen 2009.
Klockan är i mycket bra skick. Finns lite hairlines och någon ding på sidan men i övrigt mycket bra!
Klockan är nyservad med resultat på +2spd & 330 i amplitude.
Hard facts:
  • Chronograph
    Complicated watch with a function for measuring short time periods in addition to its function for permanently displaying hours, minutes and seconds.
  • Chronometer
    Label given to a watch which has undergone precision tests and received a certificate from an official body (COSC).
  • Date
    The day of the month, displayed in a window on a watch dial typically at the 3 o'clock or 6 o'clock position.
  • Helium escape valve
    Decompression system which allows helium to escape from inside the watch when the watch is worn for professional use in pressure chambers. (Long‑term underwater work, crude oil exploration, etc.)
  • Screw-in crown
    Self‑locking crown, screwed into the tube of the case, used for highly water resistant divers' watches.
  • Small seconds
    A hand on a sub‑dial which tracks seconds typically it completes a full rotation in one minute.
  • Unidirectional rotating bezel
    A bezel which turns in only one direction. Particularly useful for divers who cannot accidentally rotate it in the wrong direction, which could cause them to miscalculate their dive times. A rotating bezel makes it easy to measure elapsed time.
    • Bracelet: steel
    • Case: Steel
    • Case diameter: 45.5 mm
    • Dial colour: Black
    • Crystal: Domed anti‑reflective, scratch‑resistant sapphire crystal
    • Water resistance: 60 bar (600 metres / 2000 feet)
    • Calibre: OMEGA 3313
    • Self‑winding chronograph movement with column wheel mechanism and Co‑Axial escapement. Free sprung balance, with date, hour, minute and continuous small seconds hands, central chronograph hand.
    • Power reserve: 52 hours
    • Type: Self winding
    Tack för annonsplats KS & ett fantastiskt forum!!
    239.7 KB · Visningar: 9
    365.8 KB · Visningar: 9
    248.7 KB · Visningar: 9
    146.7 KB · Visningar: 8
    271.1 KB · Visningar: 12
