Säljes Watchdives WD0016D
Supreme
Nej.
Säljer en klocka i absolut nyskick.
Endast öppnad och provad(den kom idag).
Tyvärr föll den inte mig på läppen.
Frakt enligt överenskommelse.
Detaljer:
Brand: Watchdives
Model: WD Premier WD0016D
Movement: Japan VH31 Sweep Second Quartz Movement (smooth sweeping seconds hand)
Case Material: 316L Stainless Steel
Crystal: Sapphire Crystal with 5-layer high-clear AR coating
Dial: Natural Stone Green Jasper
Lume: Super-LumiNova® BGW9 (Blue)
Crown: Screw-down
Case Back: Screw-down
Bracelet: Solid stainless steel bracelet, screw pins, high-quality brushed finishing
Water Resistance: 10 Bar / 100 meters
Dimensioner
Bezel Diameter: 36 mm
Case Diameter: 39 mm (excluding crown)
Lug-to-Lug: 44.2 mm
Case Thickness: approx. 9.9 mm (including crystal)
Bracelet Width: 25 mm tapering to 18 mm
Bracelet Features: Quick-release spring bars, screw-link construction.
