Avslutad Lum-tec
  • Trådstartare Trådstartare Deleted member 7325
  • Start datum Start datum
  • Taggar Taggar
    lume
D
Deleted member 7325
Guest
Nej då pengarna går till annat
Ingen att anmärka på i skick! Buren ett fåtal gånger. Tillbehör enligt bild
Har goda referenser
https://klocksnack.se/threads/visenstam.96947/
44mm case width excluding crown
24mm lug width
Surgical grade 316L stainless steel
Threaded see through sapphire caseback
Bead blasted finish
Titanium Carbide PVD hard coating (gunmetal tone)
Double curved sapphire crystal with military grade anti-reflective coating
Swiss ETA 2824-2 automatic movement
Anti-Shock movement mounting system
200 meters/656 ft. water resistance
Black bead blasted PVD dial base
MDV Technology® dial and hands with grade X1 LOR Super-Luminova®
Screw lock crown with double diamond sealing system
High tech Viton® gaskets
Black crocodile patterned calf leather strap with PVD finish buckle
Black anti-static molded rubber strap with PVD finish buckle
Kan skickas rek som du står för annars hämtas klockan på plats i Oskarshamn
