SBEX001
«Product Features»
To celebrate its 50th anniversary, it inherited the first self-winding 10 vibration Divers idea of release in 1968, the new development of 10 vibration equipped with limited model the mechanical movement June 6, 2015 to Saturday, in Japan, then will be released in the world market. Suggested retail price of domestic at 650,000 yen + tax, it is the world's limited 700 pieces of sale.
And new development Movement Caliber 8L55
Those limited edition mounting of movement, based on the diver only mechanical movement 8L35, in order to achieve high accuracy of strongly stabilized more disturbance (impact or intense movement) is newly developed 10 vibrating mechanical movement caliber 8L55. High robustness Seiko own one-piece structure making it the new design that corresponds to the case (case back and the body part structure are integrated). Power spring, the balance spring, and uses a unique material, 10 and the long duration of up to hoist the time about 55 hours while being vibration, antimagnetic, it has been achieved to improve the impact resistance. 8L55 is, we are one by one manually assembled and adjusted by the professional skills with advanced skills in Shizukuishi watch workshop to manufacture consistently fine mechanical watches.
· Memorial model to the appropriate detail
Case form of one-piece construction that gives off an overwhelming presence, the beautiful Zaratsu surface is composed, has become a fixed characteristic appearance with a screw of the rotating bezel two by two up and down respectively. It has undergone a cutting of new a easy to turn it easy to grasp sharp style to the rotating bezel. In addition, the minute scale is a measure of divers dive time "anodized" (※) because it is marked with, there is no scar or fading even in long-term use. The index of the dial, I am using a newly developed Rumiburaito of with than about 60% improved afterglow time conventional. At the bottom, indicating a limited quantity, serial number will be engraved. Tough and dedicated replacement band made of arm familiar good strengthening silicon comes as a special specification of more limited model only.
(※) anodizing: Material to be to electrolytic treatment, a surface treatment for generating the artificial oxide film. Color is born by the refractive index of the light, you will be able to create a variety of color by the thickness of the oxide film.
«Product specifications»
domestic diver 50th Anniversary Limited
mechanical high beat 36000 1000m saturation diving for waterproof model June 6, 2015 (Saturday) will be released
Part number Suggested retail price Case material Band Material Dial color
SBEX001
world limited 700 or 650,000 yen + tax Titanium (diamond shield ※)
Titanium (diamond shield)
Black
Strengthening silicon band with for replacement ※
※ diamond shield
and the diamond shield, everyday use of abrasion, beautiful shine and of the original watch from a small wound, in order to protect a clean finish, is the surface processing technology that Seiko's proprietary.
■ glass material : Sapphire glass (anti-fog treatment)
■ waterproof performance : 1000m waterproof for saturation diving
■ Magnetic resistance : Strengthening anti-magnetic watch (JIS anti-magnetic watch two)
■ crown : Screw lock type crown
■ Other : Rotating bezel
Double lock with one push, in divers adjuster system distillate
■ Case Size : [Outer diameter] 48.2mm [thickness] 19.7 mm (not including the button protrusions)
■ after-sales service : Manufacturer Warranty 1 year warranty
[Movement Specifications]
Mechanical movement Caliber 8L55
■ time accuracy : Day difference +15 seconds to -10 seconds (at temperature 5 ℃ ~ 35 ℃)
■ hoisting system : Self-winding (with manual winding)
■ the winding duration : About 55 hours
■ frequency : 10 vibration / sec
■ Number of stone : 37 stone
■ Movement size : [Diameter] 28.4mm [thickness] 5.99mm
