Dalomo
Här är tråden för den vita Daylight passarounden. Vi fyller på med bilder och intryck under resans gång.
Fakta från hemsida:
”Time, season and darkness are analogous in the Nordics. The self-winding mechanical Daylight watch indicates day and night with its spinning globe disc, while its calculator bezel indicates the number of hours of daylight throughout the year in the four cities Stockholm, Los Angeles, Tokyo and New York. Each watch is individually numbered with corresponding certificate, signed by our watchmaker.”
MOVEMENT
Fakta från hemsida:
MOVEMENT
- Automatic self-winding Japanese movement
- >41 hour power reserve
- 6 vibrations per second (21 600 vibrations per hour)
- Antimagnetic DC : > 4800 A / m
- 24 jewels
- Rotor with ball bearing
- Shock-absorber device for balance staff
- Hour, Minute and Second indicators with hacking function
- Spinning globe disc with 24h day and night indicator
- Water resistance: 100 m
- Reference: 11112
- Diameter: 41.4 mm
- Thickness: 13.1 mm
- Lug to lug: 51.7 mm
- Material: Brushed 304 Stainless Steel
- Construction: Screw down case back and double gasket crown
- Case back: Display back
- Daylight Bezel: Stainless steel in PVD finish with brushed and knurled finish. Bidirectional with ratchets. Calculator ring with daylight timer
- Front Crystal: Sapphire with anti-reflex coating
- Back Crystal: Mineral crystal
- Anodized white
- Centric guilloche finish
- Indices in matte black
- Gradient pattern behind night/day-disc
- Matte black hands with matte white base.
- Brown satin finished aniline top grain leather with tan suede lining
- Width: 22-20 mm
- Thickness: 4-3 mm
- Stainless steel tang buckle with logo
