Min Goldfeather börjar med D1, sÄ vore december 1961 isÄfall. Och minstingen 46, sÄ april 1956 eller 1946. Fast en herrklocka pÄ 31mm borde vÀl betyda 40-tal? Den har Àven en gravyr pÄ baksidan som jag försöker översÀtta. :D
Hur som helst sÄ tillverkades klockorna dom Ären, sÄ borde inte vara helt osannolikt att det stÀmme. Cronosen har tyvÀrr inget serienummer pÄ baklocket och har inte lyckats öppna den för att kolla insidan. Borde dock vara omkring 1960. SpÀnnande i vilket fall som helst!
Lite lÀsning, saxat frÄn ett annat forum:
- Goldfeather: (Sub-brand) - A short-lived line contemporary with the first KS (1950’s) that was slimmer and not quite as high end as latter Grand Seiko’s. However, there is one anomalous model in that line - the 609000. Instead of being the "classic" ultra-slim (for it's day) uncomplicated (in the styling sense, not mechanical sense) dress watch, this one is rather "chunky"/solid and has "mod"/fashion influences, but not to the extent that most VANAC/AdVan models do.
- Cronos: (Sub-brand) - Daini designed and manufactured high-end Manual watches produced from 1958 to 1964 in 17, 21 and 23j versions. Also available as Cronos Selfdater (with date) from 1961 and Cronos Special (with extra adjustment) from 1963. The Cronos was Seikos mainstream offering in the late 50s, similar to the Marvel and was priced from JPY 5700. The Cronos line were generally precursors to King Seiko and Grand Seiko and not quite as high-end. A refinement of the Cronos movement was later used in the King Seiko.
- Marvel: (Sub-brand) - The Marvel was a Suwa watch introduced on June 10, 1956, a day that coincidentally was also "Time Memorial Day", a one day celebration of time all over Japan. The Marvel was the first modern caliber produced by Seiko and a large leap forward both for technical achievement and manufacturing efficiency. This sub-brand was Seiko's top watch line of manual-wind watches during the late 1950’s. They were made in 17j, 19j and 21j hand-wind versions and remained in production until 1959. The Marvel was priced from 4,500 and upwards which made it affordable to most Japanese.
Tack, men har redan sett det dÀr. Det har ju hjÀlpt med tidsperioderna, men inte exakta Är tyvÀrr. Men Marvel tillverkades 1958 och Goldfeather 1961, sÄ mina teorier kan mycket vÀl stÀmma. :)
Vill inte vara nÄgon besserwisser men visst Àr det vÀl första siffran som anger Äret och andra siffran/bokstaven som anger mÄnad lr? sÄ Àr det inte 01 pÄ goldfeathern?
Aldrig kÀnt pÄ en Seiko tidigare men slog till pÄ en 7548 hÀr pÄ forumet lite spontant. Kan bara konstatera att det mÄ vara min första men definitivt inte min sista Seiko
Jo, men det var ett annat system tidigare, som byttes till det nuvarande nÄn gÄng i början av 60-talet (sÄ vitt jag vet). Marveln har D8 i början och Goldfeathern D1, enligt nedan:
Bonusbild pÄ Goldfeatherns urverk. :D
Senast Àndrad:
Kommer lÀgga ut denna pÄ Köp o SÀlj under kvÀllen men ger Seikofanatikerna i detta hörn av forumet lite försprÄng :)
Kommer pÄ titanlÀnk, fullset och i skick som ny.
SBDJ013
Hur mycket större Àn en SKX kÀnns den dÀr? SÄ sabla snygg, men 44 kÀnns vÀl hÀftigt för mig som har problem med 42
AjdÄ, dÀr ser man, man kanske ska lÀsa pÄ lite mer innan man yttrar sig :oops: men jag fick lÀra mig nÄgot nytt i a f, har inte sÄ gamla Seikosar, 64:a Àr den Àldsta, fina ur i vilket fall som helst.
Ajajaj! Tappade min SNK809 (tror jag den heter) i ett betonggolv. Nu drar den sig ganska mycket och man kan se att den har mycket lÄg amplitud genom glaset pÄ baksidan. Finns det nÄgot jag kan göra eller Àr det bara att klicka hem en ny? Tror bara den kostade 500 sÄ en reparation kÀnns inte aktuell. :banghead:
Om den gÄr för fort sÄ lÄter det som att fjÀdern hoppat. Om du inte vill pröjsa nÄgra 100 för att fÄ det fixat sÄ kan du testa att slÄ klockan pÄ sidan ganska hÄrt mot insidan av handen. Ibland hoppas fjÀdern rÀtt dÄ.
Min Goldfeather som jag postade ovan skenar, ska testa den metoden innan jag lÀmnar in den pÄ koll! :D
Hej,
Ursakta saknaden av prickar over bokstaverna.
Fick igar hem min efterlangtade Seiko SKX009. Ivrig som jag var stallde jag in tid, dag och datum funktion igar kvall. Idag marker jag att datumet borjar andras runt kl 11. Jag stallde da om datumet korrekt. Runt kl 15 marker jag att dagskivan andras. Den har jag hittillls latit vara.
Jag laste nyss att man endast ska stalla in dag- och datumvisning innan kl 21-04, annars kan klockan ga sonder. Stammer det?
Hur staller jag in dag och datum pa basta/ratt satt?
Tusen tack for svar! :rolleyes:
Hej,
Det stÀmmer att man ska vara försiktig med dag/datum runt midnatt. Men din klocka gÄr 12 timmar fel. ;)
Hej,
LÄter som att nÀr du tror att din klocka visar 11.00 pÄ dagen sÄ visar den egentligen 23.00 pÄ natten. Det Àr vÀldigt vanligt att dag och datum pÄ den klockan drar ut pÄ skiftet, alltsÄ att dom inte byter kl 00.00, utan att det tar ett tag. GÀllande att man inte ska stÀlla datumet under den tiden, sÄ har jag lÀst att det Àr nÄgot med det verket som kan knasa till det om man gör det.
Haha, okej! DÄ fÄr den vara sÄlÀnge, sÄ lÀmnar jag den pÄ service istÀllet. Tack för varningen! :)
Kan ju vara att den blivit magnetiserad pÄ ngt sÀtt, lr att det Àr en smutsig balansfjÀder som har klibbat i hop, har en Seiko som gÄr 10 min för fort pÄ en timme:wideyed: men vet inte vad det Àr för fel, balansfjÀdern ser ok ut och har gjort en avmagnetisering sÄ förmodligen behöver den en service, kan va vÀldigt torr.
Tack för tipset! Var kan man göra en avmagnetisering i Stockholm och vad brukar en sÄn gÄ pÄ?
