@MattWServices If you want to edit a post you have to press the ... in the bottom left corner which brings up a menu but the only option available is to edit the post. Perhaps it could simply be replaced by an edit button?
That's only on mobile, and is by design as part of the responsive elements which get hidden based on view port width. Other people have additional items in there based on their user permissions, such as Admin and Moderators.@MattWServices If you want to edit a post you have to press the ... in the bottom left corner which brings up a menu but the only option available is to edit the post. Perhaps it could simply be replaced by an edit button?
So...that's a no?That's only on mobile, and is by design as part of the responsive elements which get hidden based on view port width.
Much better but the problem of a non intuitive and perhaps easily missed menu option is still present, it's merely been replaced by a more commonly used option.Is it better now? I've swapped the Edit and Report links around, so at least Edit is now first.
If you are on mobile most of the time, just use the emojis provided by your mobile device, as they are now supportedWhile we're at it, are there any plans on adjusting the whole smiley situation? If I may propose a suggestion it would be to have a fixed smiley button instead of having to open the menu each time and also have the smiley section close once a smiley is selected since I assume it's pretty rare that people use several consecutive smileys.
True, but regular users only have the 2 options in there, I have 6.Much better but the problem of a non intuitive and perhaps easily missed menu option is still present, it's merely been replaced by a more commonly used option.
This will because as a non Swedish speaker, I've been using Google Translate for the phrases to translate. If you can grab the phrase, plus the correct version, I can easily fix it.When I replied to this post I also noted that it said "HSK sa" (HSK said expressed in an informal way) which I would suggest be replaced by HSK skrev which seems more grammatically correct and was the default before the update.
Done
That's because of how the unfurl functions works in the new version.I noticed in the post above that the breif description is from the first post of the page rather than the actual post being referred to which is slightly confusing.
https://klocksnack.se/threads/klocksnack-uppdatering.139604/post-3563822
So going back to this, the top page numbers are hidden by default, people asked for them back on mobile, which I have had to do via CSS edits. It's a trade off having the page numbers plus the thread functions.Ett stort steg i rätt riktning. Beskrivningen i forumdelarna är borta vilket också är en klar förbättring men man kanske kan komprimera ytterligare på mobilsidan? T.ex. genom att minska dödytan och ha bevakaknappen på samma rad.
Oavsett vad man tycker om den nya uppdateringen så ska ni ha cred för att ni är lyhörda och tar till er av den konstruktiva kritiken här i tråden och vidtar snabba åtgärder för att försöka att förbättra användarupplevelsen.![]()
I know how to use BBCode for URLs but I'm not really sure what you mean by inline. Are we supposed to use <[inline] > or could you please explain what you meant?That's because of how the unfurl functions works in the new version.
It will display a brief snip of the page.
If you want to just post a link, use the inline code or the BBCode for URL
This is the link to that post directly.
markdown code is supported now, soI know how to use BBCode for URLs but I'm not really sure what you mean by inline. Are we supposed to use <[inline] > or could you please explain what you meant?
I tried doing it below but the inline tags are visible which I assume they aren't supposed to be. Were you referring to using regular quotation marks?
[inline]https://klocksnack.se/threads/klocksnack-uppdatering.139604/post-3563872[/inline]
"https://klocksnack.se/threads/klocksnack-uppdatering.139604/post-3563822"
```YOUR TEXT OR URL```
TESTING
[icode]YOUR CODE or TEST[/icode]
Tycker följande;
1. Bra ny funktion med att få tips på nya liknande trådar! Men finns det andra bra funktioner, vet ej? Ska jag gissa mig fram på vilka andra nya funktioner som finns?
2. Törs ni ta negativ kritik? Vill ogärna skriva det eftersom jag verkligen gillar Klocksnack men jag tänker att ni vill väl inte bara ha medhårsstrykare? Fult teckensnitt, ful design, allt känns web ala förkrigstiden men ni lever väl säkert med någon template där det finns begränsade möjligheter till att justera dylikt. Jag har o andra sidan aldrig sett ett snyggt designat forum för den delen heller och det är säkert av den anledningen att det finns få templates att jobba med.
3. jag vet inte om det är privata meddelanden mellan två forummedlemmar jag ser? se bif bild.bild..![]()
ah, vad bra tänkte det var någon bugg. som du är inne på; skapar förvirring i min hjärna i varje fall.Du ser Profilinlägg, inlägg som folk gjort på andras profiler. En åldrad funktion som jag gissar skapar mer förvirring än nytta.
"Vad är nytt" (Fattas det ett frågetecken?) uppe till vänster i menyn låter lite krystat. Vad sägs om "Nya inlägg" eller min favorit "Nyheter" helt enkelt?![]()
Håller med, jag har 100% färgseende men sitter ändå och kisar och undrar vilken sida jag är på!Den aktuella sidan får gärna tydliggöras lite bättre. Svårt att se skillnad på ett par procent av grått ;-)
