Senaste nytt från Crepas. De verkar inte ha fått in 100 backare på Hydrographer ännu. Den är lite special, med tumörkrona och allt, men jag tycker Hydrographer 1942M är skitcool. Är jag en av få? Vad tycker ni?
Dear BOGATIR,
We would like to thank you the purchase of the Hydrographer. We have received the first pre order of 50 euros. When we get 100 backers we will ask you the second payment for the pre order, this is 200 euros more. The balance will be paid one month before of the delivery.
We are very grateful and happy with all the bookings we have received but we need your help so please share and support this project along the forums and social media channels. We will be thankful to you!!
Please if you have any idea or suggestion to improve this project please let us know because we can study. It would be a pleasure to hearing from you.
We would like to give more details about the CREPAS HYDROGRAPHER model.
The movement, an ETA 2892-A2, would be modified at Switzerland to get a stem with only two positions: position 0 for manual winding and position 1 for setting the time. The stem position for stting the date would be removed, not only taking off the date disc, all the date system and stem positions would be modified to get only two position instead the three position.
ETA 2892-A2 Top grade or Elaboree grade pending to confirm.
Assembled and tested in Switzerland.
Solid stainless steel crown. The crown has not a canteen design.
Standard system to change the straps using a 22mm spring bar with 1,80mm diameter.
Black textured dial.
The crown is 9mm long and 8,50mm diameter.
It is possible to order the HYDROGRAPHER with the crown at 9 hour position.
The automatic helium valve would be placed at case back cover.
The the bezel would be turnable to the left.
The side of the sapphire lens would be polished.
Each customer would receive a made to measure leather strap manufactured by Jacobstraps.
The price of the model for the 100 customers is 699 euros (including shipping cost but plus 21% for European residents)
We have made a comparison between the HYDROGRAPHER and the Tektite models in order you could compare both sizes.
Please contact me for any further assistance.
Best regards.
CREPAS WATCHES
TACTICO WATCHES
Jag gillar den som sagt. Gillar det mesta med Crepas, och de modeller jag ägt, Tornado samt L’ocean har varit sinnessjukt fina. Så ska bli spännande att höra vidare om denna.
Miyotan rockar ju, men Pelagosen med -25s/dygn borde vara ett garantiärende?
Närå, bara jag som fuckade upp när jag ställde den och inte märkte att minutvisaren var fel. Den fortar 4-5s/dygn ungefär. Fortfarande otroligt att Miyotan drar sig typ 0.5s/dygn :D I skrivande stund har Pancoren dragit sig 2s sedan i måndags. Helt galet från den lilla japanen!
Evant Decodiver blev för blev svår att motstå när det dök upp ett mail från Gnomen tidigare i veckan.
Deras förra modell Tropic Diver sålde slut rätt så snabbt så det var bara att utnyttja läget.
Imponerande snabb transport från Signapore.
Beställde tisdag, skickades onsdag och fanns hos mitt ombud igår, fredag.
Hade svårt att fatta beslut om den limiterade DB (dubble black) eller den blå tavlan, så det blev båda...
Kul, säg till när du tröttnar :)
Dåså! Blev liten ledsen först, men vafan Länge leve Miyotan!
Riktigt fina bägge två! ;)
Mycket fina, inspirerande köp! Gillar att du körde på bägge för att slippa beslutsångesten! Grattis!
Kan nog vara att en av dom så småningom säljs, men båda stanna nog kvar ett tag.
Jag tycker båda är grymt snygga och modellen sitter bra på handleden med sina 41 mm och relativt låga höjd.
Komforten är bra mycket bättre än till exempel min Zelos Hammerhead.
Lite vidare tankar kring vintage suben!
Ofantligt mycket klocka för pengarna! Riktigt fin oysterlänk som är riktigt bekväm, keramisk borstad vridring, 90S5-urverk (går - 2 sek per dag hittills) och riktigt bra lume för drygt 2500 kr känns otroligt bra.
Det enda som är att klaga på är dom små missarna av färg på vridringen, annars känns allt kalas!
Ni som funderar på att köpa, köp! Jag är redan sugen på att köpa en med grön sunburst :)
Snyggt som fan! För mig som inte bryr mig ett dugg om det är en homage eller inte så är fan denna klocka riktigt nice!
Och får jag besvära herrn om handledsstorlek. Jag brukar tycka att subben sitter ganska litet på mig.
Någon som testat Åkerfalks klockor? Råkade se en annons på facebook och tyckte de var rätt snygga.
De har bara en modell i några olika färger verkar det som. Letade förgäves efter recensioner.
Hade gärna sett att de sålde en variant med mekaniskt urverk.
Specs
Boettstorlek: 40mm
Tjocklek: 10,4mm
Urtavla: Sidenvit
Boettfärg: Silver, rostfritt stål
Urverk: Ronda 515.24 Quartz
Lug storlek: 20mm
Vattentålig: 5ATM Garanti: 24 månader
Riktigt läckra! Slit dem med hälsan :)
Specs
Boettstorlek: 40mm
Tjocklek: 10,4mm
Urtavla: Sidenvit
Lug storlek: 20mm
Jag tänkte precis skriva att den klockan var nog inget för mig men sedan såg jag en vit tavla lite längre ner på sidan som såg rätt trevlig ut, hmmmm.....
P.s. länken är fel, https://akerfalk.se
Visst är det något som ändå lockar med dem?
Någon på planeten måste ju ha köpt en och skrivit en rad eller två?
Jag hittade lite på en indiegogo men inget var riktigt relevant.
Länken är fixad nu, tack :)
Grattis!
Mmm, en blå tack :hungry:
TSAO Balitmore just introduced an upcoming KS campaign for a new diver called Torsk.
I'm guessing some here have a "strong" opinion about the name....? :D
https://www.torskdiver.com/
Specs:
43mm 316L stainless steel or CuSn8 bronze case.
51,5mm lug-to-lug height.
22mm lug width.
14,7-15,5mm height (not finalized).
Stainless steel caseback(both types) with sapphire exhibition window.
300m/1000ft water resistance.
Miyota 9015 automatic movement: 24 jewels, 28.800bph, 42 hours power reserve, hacking, hand winding, and custom red rotor.
Domed sapphire crystal with AR-coating.
Domed sapphire crystal bezel, 120-click unidirectional.
6-clock date window
Screw-down crown at 3'oclock and a helium escape valve.
Super luminova C3 lume on indices, hands, crown, and bezel.
Stainless steel on bracelet and bronze on brown leather strap with quick release.
Included watch winder and a 2 year warranty.
Specs:
22mm lug width.
6-clock date window
Excellent name! :D
Specs:
22mm lug width.
6-clock date window
Haha. Lovley looking watches. Albeit a bit big. But that name would stop me getting one, i mean come on. Torsk?!
Nog för att jag är en "klock-torsk" men detta tar ju priset :D
Specs:
22mm lug width.
6-clock date window
Looks awesome! But its to big for me sadly :(
Specs:
22mm lug width.
6-clock date window
Named after the USS Torsk Warship. Jag tycker den var cool!
