Tack för ditt svar!Du kan bada med den, alla METAS-klockor testas i vatten.
Så här står det på Omegas hemsida:
"All current OMEGA watches are water resistant to the depth defined by the model specifications, provided that the components ensuring the water resistance are intact. This means that an OMEGA watch that is water resistant to 30 metres can be worn for swimming at depths of up to 30 metres underwater for extended periods without restriction."
