Missade gruppköpet pÄ denna med en hÄrsmÄn efter att ha velat fram och tillbaka under dagen. NÀr jag bestÀmt mig för att köra sÄ var det sent, ha ha! Typiskt. Kanske dyker upp ett lÀge att skaffa den lÀngre fram. Den Àr riktigt fin!
LÀr dyka upp nÄgra pÄ K&S ganska snabbt efter release om jag kÀnner folket hÀr rÀtt. :D
Min tredje och finaste Alpinist. :D
Senast Àndrad:
Det finns rykten om att det finns fake av just den modellen.
LÀs hÀr:
fake or franken-Cocktail Times being made now - see these images: https://imgur.com/a/24pzzT1
And this post on reddit: https://www.reddit.com/r/Seiko/comme...r_not_presage/
The incorrect details I can notice: The “TWENTY-FOUR JEWELS” text on the rotor looks wrong to me - it should be narrower, it’s too large (as is the "4R35A" and "JAPAN" text), plus the text should say "TWENTY-THREE JEWELS" even though the movement actually has 24 jewels. The “SEIKO” etched onto the case-back is also wrong - the letters are too spread out from each other, they should be closer together. The crown is the wrong shape, the wider end of the triangle shape looks too sharp, and the ridges on it look too closely-spaced, they should be further apart. Apart from the "SEIKO", all the rest of the information on the case-back is stamped or engraved, where it should be laser-etched. The shape/profile of the case-back is wrong - it's almost flat, with a round edge, whereas the real one has a definite transition in angle to it, from a flat surface to another angled, flat surface, and then another angled, flat surface. The “S” on the crown also looks to be too shallowly-engraved to me. The rotor should be one of the gold ones with more holes in it. The date disk colour is white where it should be black. The dial looks too dark to me, too, and there's not a strong enough gradient or reflectivity to the dial, and the way the pattern's made looks kind of wrong, though I can't say specifically why, but saying about the dial is hard due to possible lighting effects. Another commenter on reddit notes other incorrect details with the watch. I knew that there were several models of fake Turtles (the ones that say "NH36-336LT" at the bottom of the dial, and have wrong case-shapes and bezel inserts: https://orologi.forumfree.it/?t=75907317 , fake STO with no dial code at 6 and shape of lines on dial is wrong, too straight, and no darker crown and bezel: https://upload.forumfree.net/i/ff106...A822E7A46.jpeg), but I didn't know that there were fake Cocktail Times out there!
Precis.
Den ser defintivt fake ut.
Kolla pÄ "Made in Japan"
SÄ stort skrivet Àr inte Seiko's, Àven rotorn ser billig ut. Ska inte rotorn ha nÄgon slipning, likt i stilen som SARB033, 35?
Även S:et pĂ„ kronan ser fake ut.
Provade den hÀr hos Klockmaster Globen idag som tÀnkt första klocka Ät en 15-Äring. Gillade verkligen hur den satt pÄ handleden trots sin storlek.
Köpte den hÀr frÄn @Spincini till hans storebror nÀr han fyllde 15. Kom Àven med lÀnk och det blev en succé.
De delar vÀl urverk om jag har förstÄtt det rÀtt och jag tycker att de skiljer sig sÄ pass mycket med sifferindex, andra visare och helsvart tavla.
Vad sÀger ni som Àr Seiko-experter pÄ den extremt subjektiva frÄgan om klockorna kommer kÀnnas likvÀrdiga i tonÄrsögon?
LikvÀrdiga klockor men vÀldigt olika i utseende. Den du kollade pÄ i Globen Àr mer konservativ i utseendet, speglar den femtonÄringens personlighet?
Han Àr inte riktigt samma finlirare som sin storebror, och den hÀr kÀndes mer beateraktig som jag tror passar honom mycket bÀttre. Den jag köpte av dig ser identisk ut nu som dÄ trots att den anvÀnds sÄ gott som varje dag. Han Àr extremt noggrann med hur han bÀr sin klocka. Hans lillebror Àr inte riktigt lagt Ät det hÄllet :)
LĂ„ter som en bra matchningar:)
Korspostar lite hÀr och dÀr. Blev sÄ nöjd nÀr den satt pÄ armen. Ovanlig och mycket skön lÀnk Z199 - enda som duger nÀr gummit vilar. Seiko 7548-7010
Glad Valborg Seiko-kamrater!
Senast Àndrad:
