Sorubim
Audemars
3. Vad anser ni om SKA427P2? Blottar min okunskap igen men vad menas exakt med att ett urverk Àr "Kinetic"? Bra eller dÄligt?
SÀkert en bra klocka pÄ mÄnga sÀtt, jag kommer nog aldrig skaffa nÄgon iaf... pga...
![Hilarious :hilarious: :hilarious:](/styles/baisik/xenforo/smilies/hilarious.png)
![Facepalm :facepalm: :facepalm:](/styles/baisik/xenforo/smilies/facepalm.png)
Tack för informationen om den modellen! DÄ stryker jag den genast frÄn min önskelistaSÀkert en bra klocka pÄ mÄnga sÀtt, jag kommer nog aldrig skaffa nÄgon iaf... pga...
AngÄende skillnaden mellan SKX007J och SKX007K...
Klippt och klistrat frÄn en trÄd pÄ watchuseek:
"There has been much discussion over the years about these two watches (along with the SKX009K/J and SKX011J/K) as to whether one is "better" than the other etc. The consensus is that they are the same watch except for the different dial and caseback. Now is the SKX007J actually made in Japan while the "K" comes from Singapore (or now Milaysia?). According to Seiko the "J" is marked differently for different markets. From the SCWF Dive Reference:
"There has been extended discussion among Seiko diver collectors on the differences between SKX007J and SKX007K. The SKX007J has extra text on the dial that's not on the SKX007K -- "21 JEWELS" under "DIVER'S 200m" and in small lettering "Made in Japan" along bottom edge of dial below 6 o'clock. Some people have said the SKX007J is made in Japan and the SKX007K is made in Singapore and the Japan-made model seems to be better. Others argue there's no proof of the country of manufacture or of any difference in quality between the divers. Many people on the S&C Forum have concluded that there is only cosmetic but no real difference between the J and the K variations -- they are all great divers.
In answer to the question, "What are the differences between SKX007J and SKX007K?," Seiko Japan said: "The watch ref.#SKX007J and SKX007K are completely same watch model. The shipping route is slightly different. We are not able to inform you of the details" (email from Seiko Japan Service Group, 10/28/02). "
Even if the "J" is made in Japan and the "K" is made in Milaysia (now in Milaysia; used to be Singapore) the machines and robots that make the movements and watches would be the same in either country so the techniques and procedures would be the same regardless of where the actual watch is produced.
So, if you just have to buy a watch that says "Made in Japan" on it the SKX007/09/011 is for you. If you want identical quality and want to save a few $ then the "K" variant is for you. Personally I wear the SKX007K more than the "J" as I like the cleaner look better. This is purely a subjective thing and as they say: "your milleage may vary"."
HÀrifrÄn: http://forums.watchuseek.com/f281/differences-between-skx007k-skx007j-explained-81783.html
Fy! Du fÄr nog köra hela klockan i UL-tvÀtten!![]()
Bonusbild.
Glöm inte trycktesta era klockor.![]()
Grymt cool med cermet-shroud!SĂ„. JĂ€vla. Snygg.
Efter expressleverans och maxmoms sitter nu denna pÄ.
Otroligt hÀrlig. Har aldrig haft en Tuna med polerat shroud innan. Det gör den lite speglig och inte lika in your face som andra modeller. Den kamouflerar sig lite bland armhÄret liksom.
Riktigt polerat cermet ( Cermet Àr en blandning av keramik och metall. Kort sagt hÄrt som keramik men kan poleras/skÀrpas som metall. AnvÀnds t ex av Sandvik för att skÀra till stÄl i lagom stora bitar) i ytterskalet. Klockan sju pÄ klockan ser ni min flaggstÄng.
Riktigt bra IMO att de nöjt sig med att sÀtta nya prospexloggan pÄ kronan.
Bandet Àr nya mjuka blandningen och inte vitt. Snarare ljust ljust beigegrÄblÄ. Snyggt med svart keeper. Och gött knottrigt pÄ insidan for pleasure.
Lysmassan Àr nya lumibriteblandningen som skall vara sextio procent effektivare Àn gamla. SÄ den Àr sÄklart som en jÀvla hÀrdsmÀlta. Kul med lys i ringen.
Enligt Lisa sÄ det dessutom den minst fula av alla tunas jag har. Ok betyg ÀndÄ.
Sbbn029 Àr referensen.
Grattis till en grym dykare John!SĂ„. JĂ€vla. Snygg.
Otroligt hÀrlig. Har aldrig haft en Tuna med polerat shroud innan. Det gör den lite speglig och inte lika in your face som andra modeller. Den kamouflerar sig lite bland armhÄret liksom...
1: Den man gillar.Ber om tÄlamod för mina frÄgor nedan, som Àr pÄ basnivÄ för er och kanske besvarats i trÄden.Men hur som helst, here we go:
1. PÄ ex uret.se sÄ finns ett antal Divers. Vad Àr skillnaden mellan de olika SKX007-modellerna? Vilken Àr den man skall ha anser ni?
2. Av samtliga Seiko Divers, vilken Àr den ultimata modellen?
Tack pÄ förhand för era expertsvar!
Tack för tipset om SBGA031! MÀktig! Ha ha ha...kommer aldrig införskaffa en SKA427P2. Det Àr sÀkert!1: Den man gillar.
2: SBGA031
3: SĂ€kert helt OK, men jag fixar inte heller snoppvisarna.
Aha! Bra att veta. Tackar för det!@Greven
Diver's Àr för övrigt ett skyddat namn som bara fÄr skrivas pÄ klockor som uppfyller ISO-kraven för dykarklockor pÄ 200m. Det Àr alltsÄ en kvalitetsstÀmpel som dÀrför bara stÄr pÄ vissa klockors urtavlor. Det Àr dÀrför det inte stÄr pÄ exempelvis SEIKO 5-modellerna. TÀnkte att det kan vara bra för dig att veta om du letar efter en billig SEIKO.À som ska klara dykning.
Om du Ă€r utan för komfortzonen (Skandinavien) glöm ĂĂĂ det blir bara problem.Lite off topic.
NĂ„gon som bestĂ€llt frĂ„n Chino och vet om deras bestĂ€llningsformulĂ€r fixar Ă ĂĂ? Har fullt med sĂ„dana tecken i bĂ„de namn och adress och vill inte att det ska bli för kryptiskt för posten.Eller Ă€r det bĂ€st att bara anvĂ€nda A & O nĂ€r man lĂ€gger bestĂ€llningen?
Sitter med avtryckarfingret pÄ köpknappen.![]()
Hade mailat in bestÀllningen istÀllet.Lite off topic.
Tjena,
Jag och en polare letar efter en skön Seiko klocka, den skall vara chronograph med lÀder och helst inte med ett Quartzverk. Finns det nÄgon vÀnlig sjÀl som kan ge oss en hint om ett par snygga modeller som passar in den beskrivningen?
Tack pÄ förhand!
Oskj93
Googla pÄ SEIKO SDGZ alternativt SEIKO Ananta. Vissa sÀljs med lÀnk och lÀder, men de flesta enbart med lÀnk. LÀder kan man köpa billigt separat. RÀkna med att ni fÄr lÀgga MINST 10000kr för en ny automatisk kronograf köpt frÄn Japan och det dubbla frÄn Sverige.Tjena,
Tack pÄ förhand!
Oskj93
Vad har ni för budget? Nytt eller begagnat?
NÀstan olösbart. SEIKO gör bara bra mekaniska kronografer och dÀrför kostar de mer. Vintage gÄr dock att hitta billigare. Kvarts finns sÄklart mycket billigare.Tja, vi har en budget pÄ 5-10k var drygt och den ska vara ny!
Jag har ett Black Badger 26 mm kvalitetsstrap gjort ursprungligen för min Velatura 8r28 kronograf, som ligger hemmavid. I nyskick. PMa om du behöver mer infoSÄ kom den Àntligen, fan sÄ en vÀntat! Spontana intryck: Superb kvalité, verkligen fin i alla avseenden. Detaljerna pÄ tavlan, boett och gummi Àr av högsta klass. För det pris jag gav, skx-pengar (den Àr ny) Àr det vÀldigt mkt klocka för pengarna! Ruggigt nöjd Àven fast modellen i sig kanske inte Àr sÄ poppis
Lite bilder, 44mm stor utan kronan men inte sÄ lÄng och formad boett sÄ klart bÀrbar
Enda trÄkiga var att gummits form inte helt passade mina handleder just nu, mÄste töjas lite i sista hÄlet. Annars blir det köpa ett annat 26mm band. Men ska nog mjukas upp efter lite smÀrta/kokning![]()
Kolla Rakuten eller Yahoo Japan och sök dÀr pÄ SEIKO SDGZ sÄ fÄr du en prisuppfattning. DÀrtill fÄr ni rÀkna med 25% i moms + 500kr i frakt. Blir nog svÄrt att hamna under 15 om ni mÄste köpa en ny. Bor ni i STHLM sÄ rekommenderas sÄklart ett besök hos Klockmaster Globen.JasÄ? Hur mycket behövs det gÄ upp i pÄ ett ungefÀr?![]()
