Jag har skruvat i en del äldre ryska verk nyligen där ingen har regulator för haltning och fick justera precis som du gör. Däremot läser jag en bok nu där han pratar om någon (enligt författaren - Donald De Carle - bättre) metod. Jag flyttar runt balansenfjädern tills jag tycker att sitter precis i mitten mellan 'banking pins'. Så här skriver han dock:Det man måste göra är att komma åt spiralrullen, den del som spiralen fäster i innerst. Den gömmer sig under balanskloven, man kan låta balansen hänga ner från kloven, som man fäster på en hållare, och sen gå in mellan spiralens varv men det vågar inte jag![]()
"For the escapement to be in beat the ruby pin should be in the center of the lever notch when the balance is at rest and the mainspring unwound. This is not always a convenient way to make the test: neither is it always accurate. The beat is a compromise depending upon slight inaccuracies in the escapement. The best method of testing for beat is to wind the mainspring two or three turns with escapement fully assembled. Hold the movement in the left hand and with the pointer in in the right try to stop the balance vibrating. In a well proportioned and correct escapement it will be found that it is not possible to stop the balance. If it will not 'set', the balance is in beat. In many watches it will be found that the balance will set, and the test then is to see if the balance sets on one side more than the other. The balance is in beat if the balance sets an equal amount on both sides. That is , during the operation of both pallets. To instance a definitive case lead the balance round by holding the pointer so that the arm of the balance rests against it. The balance is travelling so that the entry pallet locks on the tooth and the balance sets; move the pointer to the other side of the arm and move the balance to unlock, the balance will then swing smartly round a half turn arrested by the pointer. Continue to lead the balance round until it sets on the exit pallet. Move the balance to unlock again and we note that it was necessary to move the balance further to unlock on the exit pallet than on the entry pallet, indicating that the balance spring collet must be moved towards the exit stone. The necessary amount of movement to give the collet cna only be discovered by trial."
Jag har varken testat detta eller fullt förstått det helt ärligt. Kommer dock att testa mig fram med något skrot verk framöver. Någon här som känner igen metoden och kanske har bemästrat den? Ursäkta för lång text men det var jobbigare för mig att skriva det än för er att läsa det
