Detta är SBDC107 / SPB149
Diameter: 40.5 mm
Height: 13.2 mm
Material: Steel
Water resistance: 200 m
Movement: 6R35
Features: Hours, minutes, seconds, and date
Winding: Automatic
Frequency: 21,600 beats per hour (3 Hz)
Power reserve: 70 hours
Det är alltså denna fast med svart tavla, SBDC101 / SPB143 som jag tänkte vi kan köra gruppköp på.
Hade behövt en grov missräkning av Skatteverket så att man hade kunnat gå lös på denna release. Är så många jag skulle vilja addera till samlingen. Omöjligt uppdrag att bara välja en.
Model: SPB147J1
Case Material: Stainless steel case
Movement: 6R35
Jewels: 24
Power Reserve: 70 hours
Crystal: Curved sapphire with inner anti-reflective coating
Water resistance: 200m
Diameter: 40.5mm
Thickness: 13.2mm
Price: TBD
Model: SPB151J1
Case Material: Stainless steel case and band with super-hard coating
Movement: 6R35
Jewels: 24
Diameter: 42.7mm
Price: TBD
Model: SPB153J1
Movement: 6R35
Jewels: 24
Diameter: 42.7mm
Price: TBD
Model: SLA042J1
Case Material: Titanium case with black hard coating, Ever-Brilliant Steel bezel with rose gold color coating and ceramic outer case
Movement: 8L35
Jewels: 26
Power Reserve: 50 hours
Crystal: Sapphire
Water resistance: 1000m
Diameter: 52.4mm
Price: TBD
Model: S23629J1
Case Material: Stainless steel case with super-hard coating
Movement: 7C46 (quartz)
Crystal: Curved sapphire crystal with inner anti-reflective coating
Water resistance: 300m
Diameter: 47.7mm
Price: TBD
Model: S23631J1
Case Material: Titanium case with super-hard black coating and ceramic outer case
Crystal: Sapphire
Diameter: 49.9mm
Price: TBD
Model: SRPE33K1
Movement: 4R35
Jewels: 23
Power Reserve: 41 hours
Crystal: Sapphire crystal with inner anti-reflective coating
Diameter: 43.8mm
Price: TBD
Model: SRPE39K1
Movement: 4R36
Jewels: 24
Diameter: 45.0mm
Price: TBD
Model: SRPE35K1
Movement: 4R35
Jewels: 23
Diameter: 43.8mm
Price: TBD
Model: SRPE37K1
Movement: 4R35
Jewels: 23
Diameter: 43.8mm
Price: TBD
Model: SRPE27K1
Movement: 4R36
Jewels: 24
Crystal: Hardlex glass
Diameter: 42.4mm
Price: TBD
Model: PB155J1
Movement: 6R35
Jewels: 24
Water resistance: 20 bar
Diameter: 38.0mm
Price: TBD
Model: PB157J1
Movement: 6R35
Jewels: 24
Diameter: 38.0mm
Price: TBD
Model: PB159J1
Movement: 6R35
Jewels: 24
Diameter: 38.0mm
Price: TBD
Men herre vad händer, fan va kul allt plötsligt blev! Gick in och kollade nyheter från GS i morse och checkade ut mentalt när de släpper en dykare på 46,9mm, men nu är man tillbaka i matchen!
Det är den här jag stannar vid varje gång jag scrollar genom nyheterna. Äntligen en behaglig grön färg. Kommer behöva köpa den, bara att hoppas att priset inte blir på tok för orimligt.
Tack, ser nu att det redan avhandlats här i tråden men får skylla på att det är svårt att hänga med i det här tempot. Så det är alltså den här och samma modell fast med grå tavla? 15-ish för den grå och någon tusenlapp mer för den blå om jag förstått det hela rätt? https://www.seikowatches.com/jp-ja/products/prospex/sbdc107
Wow! Här är det bara att hålla i sig! Kan bara stämma in i kören - Seiko har skruvat upp allt ett snäpp! Grymma släpp! Nu får jag snart slut på utropstecken!!!
Tror SPB147 är en sleeper pick asså. Ser skittråkig ut på bild, men när det där guldet får glimma till i solnedgången, då jävlar kommer den knocka BB58 ur parken så att säga!
