Dags att fixa nödvändigheter för helgen.
Rätt hylla att handla vid! Its Norrlands time!
SUPERMAN HERITAGE GMT: A SUCCESSFUL COLLABORATION
Thanks to all of you the Superman Heritage GMT Co-Labs project is now a reality!
After several months of work, from designing to prototyping, YEMA is pleased to introduce the Superman Heritage GMT.
This new Superman GMT is inspired by the original Superman 53 00 16 from the 1970s and the Superman Heritage with its round markers, case, and bezel.
Following your votes and comments, we selected 3 different bezels to dress up this brand new Superman GMT. Traditional colors with the Pepsi and Coke bezel, and a more innovative one in Blue/Grey. These bezels will be made of aluminum, the same material as the original Superman.
With its ability to show two different time zones, the latest model is equipped with a Swiss ETA 2893-2 movement, renowned for its reliability and sturdiness.
The Superman Heritage GMT comes with a 39mm case and “Oyster” bracelet made of brushed stainless steel. It’s divers extension reinforces the “toolwatch” aspect to please all globetrotters, whether they are divers, explorers, businessmen or simply travelers.
Yema’s emblematic Y logo is engraved on the crown and the caseback proudly displays YEMA’s historic crest beautifully embossed with a hydraulic press.
The Superman Heritage GMT will be available on pre-order on Yema.com as from 22nd July. To make this timepiece even more exclusive, each model will only be available in an ultra limited series of 100 numbered pieces.
Yema CoLabs and Yema Privilege members can in all exclusively secure their numbered edition right now through 24/7 online chat on Yema.com
@MaBr, @Watchie mfl. som bär Squale 1521, hur bärs den storleksmässigt? Går det att bära upp den på 16,5 cm handled? Är det någon i tråden som har WS på 1521 på en smal handled? Det har säkert postats något sådant tidigare men det är alltid roligt med färska bilder. ;)
Snoka igenom mina bilder, jag har också 16,5cm handled! Den sitter perfekt på en smalare handled. :)
Edit : Bilder!
Det är samma på 2002:an, riktigt smart! :)
Hmmm... @MaBr har ett blått tropic liknande gummi hemma som borde passa bra på denna. Står 18mm på den, men är mer som 19mm. Postar bild när jag hämtat kidsen från dagis. Om du vill ha den så postar jag över. No charge.
Hittade den när jag semester packade en hel box med klockor och relaterat. Inte friskt ;)
Edit: glömde nämna att jag tror det är vintage. Det var därför jag tänkte på din klocka.
Bilder nedan. Skicka adress via PM så får du det nästa vecka. @MaBr
Den som är medlem i Yema CoLabs gruppen på Facebook kan reservera sitt nummer redan idag, har reserverat nummer 79 på Läderlappen och nr 75 på Coke :D
Oj, det vore väldigt snällt! :woot: Blir perfekt till hösten när "italiensk strandraggar-perioden" är över och det är dags att nyktra till igen. :p
Fasen vilken läcker klocka! Grymt att ha två på g @M26
  • Like
Reactions: M26
