Tråden om Squale
Bra tidhållning men det har ju tyvärr ingenting med COSC att göra. Ska du ens komma i närheten av ett COSC-test så får du i alla fall byta position på dem. :) Här är bara ett kort utkast om vad COSC är:
ISO 3159 gives the definition of the balance spring oscillator wristwatch chronometer. Only movements or watches that meet the accuracy requirements of this standard receive an official chronometer certificate.
The checks performed by the COSC consist of static tests performed in the laboratory. Each individual movement/watch undergoes a battery of tests specific to each of the four types, for several consecutive days, in five positions and at three different temperatures (8°, 23° and 38°C).
On the day of receipt of the movement (day 0), the COSC carries out the following:
  • tests the numbers engraved on the movement (in relation to the list supplied by the applicant).
  • places the movement in a 5-slot clasp.
  • winds the movements (delivered unwound) according to the instructions of the manufacturer
  • places the parts in an enclosure at 23°C (± 1°C), where they must remain for at least 12 hours so that their temperature stabilises before the test phase commences.
Then, for 15 days for wristwatches and pocket watches, 19 days for carriage clocks and on-board clocks, and 13 days for quartz timekeeping instruments – a long and rigorous time period – the parts undergo daily tests. Every day, including weekends, the instruments are measured and wound. On the basis of the measurements, 7 elimination criteria are calculated for Type I. If and only if the 7 criteria are met, the movement / watch is certified as a chronometer.
What are the 7 criteria?
  • average daily rate
  • mean variation in rates
  • greatest variation in rates
  • the difference between rates in horizontal and vertical positions
  • largest variation in rates
  • variation in rate depending on temperature
  • rate resumption
Tack för den utförliga beskrivningen, jag har inget Schweiziskt laboratorium hemma, det var därför jag skrev mini COSC. Mer att ha det som referens och en kul grej...nästa mätning tänkte jag skulle vara mellan 07:00 till 22:00 på armen. Men den är lite mer vanskligt beroende vad armen hittar på under dagen.
Menade bara att du borde byta position på dem varje dag. Krona upp dag ett, krona ner dag två, glaset ner dag tre osv. Det blir ju mer rättvist och mer COSC än bara en position. :)
Matic denna kväll.
Vet ej om det varit på tapeten innan men när allting väl lägger sig och återgår till det vanliga vardagliga livet; hade en passaround på någon kul modell från Squale möjlig? En peng från samtliga deltagare som täcker klockkostnaden? @Zackrissonsur.se
Det var redan planerat innan:) Vill gärna ger er något nytt, och jag tar gärna halva kostnaden själv, så ge det bara lite tid....
Tack för uppdateringen! Vi håller tummarna det inte dröjer allt för länge :)
edit: tog bort min trögtänkthet
Sorry ibland skriver jag med känslorna innan jag hinner tänka, vill bara klargöra att det finns inget fel på Er underbara eller några obesvarade mail från Er sida. Jag är ingenting utan Er och det är det viktigaste, vi skall vara billigast men också trevligast samt lyssna och lösa våra kunders problem, lösningar, special orders. Att ni hänger kvar med Era beställningar gör mig rörd, vissa har snart väntat två månader. Så det var inget mot Er utan vill bara ha svar när ni kan få Era varor.
Vajjert :)
Det jag vet är på g är T-183 svart blå, kan det vara något att testa? T-183 är sjukt fin i verkligheten, ser lite konstig ut med ränderna på bild men ibland behöver man IRL:)
Bara tanken på att för en tid få bära en klocka som burits av gigant efter gigant här i tråden gör att jag är på – så till vida att jag inte är först i ordningen det vill säga ... i så fall är jag inte med ;)
Alla händer upp i taket! Haj haj
Är T-183 en av Onda-varianterna eller är jag ute och cyklar?
Vi skullle kunna köra Onda Emerald också, den är så sjukt grym, vill egentligen inte att den skall säljas då jag helst vill ha den själv. Den kommer redan nästa vecka.Om ni är på hur skapar jag en passaround? Lägger bara ut det här i tråden? Vad är lagom 10-15 pers, en vecka var?
Ska vi inte vara fler så räcker det nog att du tar intresse här i tråden, sen kan man starta en PM-tråd med de som är intresserade. Sen när passarounden är igång så är det bästa att dra igång en separat tråd i diskussionensdelen, mest för att sprida det till fler. Bättre för din del också för du får mer exponering vilket du såklart ska ha om du sponsrar delar av kostnaden. :)
