Stort tack för tipset! Ska testa nu.Ăr inte sĂ€ker om detta löser ditt problem men du kan testa detta (Wus) :
"If you want to retain the Multiband feature while just disabling Bluetooth, press hold adjust till seconds blink, then hold button B till it says solid CLR. This will remove Bluetooth pairing from the watch, which will no longer attempt to Bluetooth sync until it is re-paired. I have very good reception at my apt so this is how I keep the watch when there. On the road, I then re-pair it with my phone for Bluetooth. For good measure, also delete pairing registration for the watch from the app as well. Works well."
Gick in i appen precis och hittade en instÀllning under "kugghjulet"->Klockans namn (CASIO GW-B5600)->Time adjustment
HÀr stÄr Àven listat alla gÄnger klockan lyckats synka mot Bluetooth och mycket riktigt lyckades den i morse kl 00:30.
StÀnger man av den sÄ stÀnger man dock av all synkning.
