Pulsen är hög, vilken rush .
Movement
- Calibre SW500
- Self-winding mechanical movement
- Chronograph function integrated into the movement
- 25 jewels
- 28.800 vibrations per hour; 4 Hz.
- Stone lever escapement
- Stop-second
- Glucydur Balance Wheel
- Shock resistant as per DIN 8308
- Anti-magnetic as per DIN 8309/ISO 764
- Movement diameter 13 1/4"" (30,4 mm)
- Incabloc shock protection
- Unidirectional self-winding mechanism with ball bearing, weight segment made of heavy metal
- Power reserve approx. 48 hours
- Movement decorated, blued screws, weight segment with engraved Guinand logo
Functions
- Hours, minutes, subsidiary seconds
- Chronograph with 30 min- and 12 hours counters and central second hand
- Date- and day of the week display
Case
- Stainless steel, polished
- Case made of stainless steel, hand polished
- Sapphire crystal glass, domed, anti-reflective on the interior
- Screwed back with crystal glass
- Screwed crown, double O-ring sealed
- Fixed bezel
- Protected pushers
- Pressure resistant up to 10 bar
Dimensions and Weight
- Case diameter: 38.4 mm
- Case thickness: 15 mm
- Band lug width: 19 mm
- Lug-to lug distance: 46.7 mm / 1.84 inch
- Weight without strap: 75 grams
