En beater av rang och nog sambons favorit. Grym klocka!
Tissot har en riktig fin på gång, 40mm och Powermatic 80 med silikondelar. Pris $1300, låter dyrt för denna tråd men det verkar som att det inte är guldplättering på ringen utan solid :wideyed::greedy::hungry::pompus:. Snygg är den iallafall.
Aggressivt prissatt måste jag säga, $1300 är ett kap med solid 18kt roséguld ring :hungry:
"The Tissot Gentleman Automatic is comprised of four new dress watches that are made of stainless steel with a solid 18 kt pink-gold bezel. That’s right, the bezel uses bona fide gold rather than being plated for appearance’s sake. Each watch is nicely sized at 40 mm by 10.64 mm"
Mer info om den:
https://www.watchtime.com/featured/tissot-gentleman-automatic-silicon-powermatic-80/
Mer info om den:
Undrar vad L2L mäter :bookworm::watching:
Mer info om den:
Än index och visare då? Borde inte de ha samma färg/egenskap/material? Hur blir det annars? Nyansskillnader?
Hoppas de inte kör silikondelar, men de har väl även plastdelar eller? Silicon är kisel.
Tavlan skvallrar om att det ska vara silikon om det är vad syftade på?
"Thanks to the labeling underneath the central axis of the dial, you can immediately tell that the movement inside is the fan-favorite Powermatic 80 that has been used in a variety of Tissot timepieces as well as extensively in the wares of sister brands like Rado and Longines. If you’re unaware, the Powermatic 80 is basically a souped-up version of the ETA C07.811 movement with an 80-hour power reserve. For the Gentleman Automatic, Tissot has added a silicon balance spring which will allow for longer intervals between service as well as greater resistance to magnetic fields. The decision to equip the Gentleman Automatic with a silicon balance comes after the Swatch Group’s recent announcement to outfit every mechanical watch produced by the conglomerate with either a silicon or Nivachron (a new material that Swatch Group developed in collaboration with Audemars Piguet) balance spring."
Mer info om den:
Hade jag lirat kostym oftare hade jag nog sltt till på den med cremetavla. Riktigt fin!
  • Like
Reactions: M26
Har hört gott om Ray II men undrar om inte gamla hederliga SKX är absolut bäst när det gäller beaters och tröttnar man så är det inte dyrt att förnya utseendet.
Har haft några SKX, men sitter dåligt på mig dessvärre, sedan är jag ej förtjust att man ej kan winda som vanligt, utan köra Seiko rycken....
