Jag trodde att det var samma urverk som sagt, men jag kan ju ha fel. Lustigt dock att 4r35 lanserades 2010 och NH35 2011 enligt goggling om 4r35 är den nyare av dem...
EDIT: Fortsatte att goggla
Caliber | NH35 | 4R35 |
Movement Type | Automatic | Same |
Outside Diameter | 27.40 mm | Same |
Total Height | 5.32 mm | Same |
Winding Mechanism | Automatic, Manual | Same |
Jewels | 24 jewels | 23 / 24 |
Accuracy
(Seconds per day) | -20 / +40 | +45 / -35 |
Vibrations (seconds) | 6 | Same |
Vibrations (hours) | 21,600 | Same |
Power Reserve | 41+ Hours | 40+ Hours |
Lift Angle | 53 degrees | Same |
Hacking / Hand-winding? | Y / Y | Same |
4R35 was
introduced in 2010 in the Elegant/Presage SARY series, and these remain in
production.
The earliest documentation on this movement that we were able to find was issued on 2/14/2011, this also corresponds with the 2011-2012 time frame that the first
NH35A powered watches started hitting the market.
