KS stora Parfymtråd
KD: Baccarat Rouge 540 edp. (Dekant)
Två spray direkt på handleden men känner knappt något. Måste lägga näsan tätt inpå för att ens känna något. Har läst att folk blivit näsblinda av den men att den samtidigt projicerar ordentligt och fyller rum.
Ni andra som testat den, hur blir det för er?
(Bild från WWW)
(Bild från WWW)
Hände exakt samma för mig när jag fick prover från Nose Paris...luktade nästan ingenting, bokstavligt talat
Senaste recensionen på fraggan förklarar lite kemi. Om det stämmer vet jag inte
”Many people are complaining about this disappearing quickly. Time for a small science break!
Two molecules make 75% of this perfume. 50% is hedione, a synthetic version of jasmine. It has extreme projection and smells like transparent flowers. 25% is ambroxan, a synthetic version of ambergris. It also has extreme projection and smells salty/aquatic. These two molecules are what those around you mostly smell. And they're what easily disappears to your own nose. Their disappearance amplifies the masculine/medicinal base notes and makes performance seem weak.
A good analogy can be found in sounds. It's easy for your brain to tune out the hum of bedroom air conditioning. Hums are simple sounds. But if someone is playing loud music upstairs, the sound's complexity and constant change will make sleeping hard. Your brain can't ignore it easily.
The same thing goes for smells. When there's a lot of complexity, like with old heavy perfumes, your brain struggles blocking out the smell. This means you're able to smell your perfume all the time. With simple modern molecular perfumes like BR540, it's easy for your brain to tune out the smell. They're the chemical equivalent of a simple hum.
The only way to smell more is by spraying less. Your nose has a cut-off point with synthetics like hedione and ambroxan. When they're faint and diluted, you can smell them. But once they get strong enough, your nose calls it quits and blocks them out completely. Applying more is a losing battle. With BR540 I never do more than one spray. It saves money, allows me to smell my fragrance better and spares those who hate the scent from torture. Your nose will also recognize the scent better once you become familiar with it. Trust me, one spray is enough to get noticed with this one!”
Mycket fin! Vet inte om jag ska slå till på Grand Soir, Ani eller Oajan. Någon blir det förhoppningsvis om rätt BF-erbjudande dyker upp. Kanske Grand Soir iom omformuleringarna som påstås träda i kraft snart.
Vad finns det för "riktig" info om omformuleringar av Grand Soir? (den har varit på min inköpslista länge och undrar mest om den kan fortsätta att vara där över jul o nyår eller om man måste slå till omgående?)
Väldigt intressant,
Och roligt med en så fin förklaring!
Dagens doft blir Xerjoff Naxos!
3.5 sprays, initial thoughts: fuck vad stark den är 😂 Men trevlig citrus, lätt tobak, lavendel, vanilj och honung. Tydligt Xerjoff DNA, sticker ut en hel del jämfört med ex Xerjoff Uden som jag köpte en flaska av för ett par veckor sedan :)
Får se om man får skäll på jobbet:
Dagens första kommentar på Naxos, tyckte själv jag luktade mycket efter 3 sprays 😂
En kollega ropar ifrån korridoren "Det luktar Richarddoft idag!" Hon kommer in på kontoret: "Är som att komma in till sockerbruket haha"
Igår snackade vi om äckliga dofter varav en annan kollega tog upp sockerbruket 😂 Detta sades dock på skämt och med glimten i ögat.
Har ingen riktig info, svårt att se att MFK skulle skylta med omformuleringar. Eller något annat märke för den delen heller. Mer en att man hänvisar till typ IFRA-regler.
Det som får mig att tro på källan är att personen har sagt samma sak som en annan KS-medlem, som jag inte har någon orsak att misstro, hört av officiell återförsäljare 🙂
OK tack, det är väl "as good as it gets" i parfym-omformulerings-svängarna... :)
Ingen info om tidsram?
Haha ungefär så 😁
Tidsramen specificerades inte men det lät mer som inom kort en att det är senare. Tydligen ska branschen anse att deras ämnen inte är upp till standard.
Eller så är det bara humbug. 100% sanning får vi aldrig.
Två dagar med MFK Oud Satin Mood. Edp vs Extrait. (Samples)
Båda öppnar upp med mycket ros. Edp är rosen mer framträdande, svårt men känns som två olika rosnoter. Extrait är det mer ros som är lite smutsig.
Men det är drydown allt handlar om. Edp är lite som öppningen på extrait. Det är smutsig ros. Fin blandning av ros, oud och lite vanilj.
Extrait bjuder på mer orientalisk drydown. Ros, oud, vanilj, kanel hintar av viol.
Båda är riktiga monster i projektion och longevity.
Som @Tjabo sa så känns extrait mindre feminin än edp.
Edp får 5/10
Extrait 7/10.
Flaskvärd? Nja, vet inte. Känns inte helt värt 3000kr, finns annat för dom pengarna. Tyvärr verkar inte extrait finnas i 30ml. Blir kanske större dekant eller ett reserör.
(bilder från www)
Edp får 5/10
Extrait 7/10.
(bilder från www)
Jag önskade att jag skulle få in en fullträff från någon av dem jag beställde hem, men nej. Jag har också svårt att hitta motivation till ett köp av helflaska hos MFK. Om det skulle vara någon så hade det blivit Oud Satin Mood Extrait. Drydownen var jävligt fin på den, dock alltför lik FdB NY 5th Avenue's drydown. Och 5th Avenue har en bättre öppning så... Nej, tyvärr.
Oud Silk Mood Extrait var ingen hit och inte heller Oud Extrait.
Grand Soir var väl okej, men där stannade också intrycket. Inte ett enda ryck i Petter-Niklas.
Jakten fortsätter. Måste prova Kilian Musk Oud, Frederic Malle Portrait of a Lady och Diptyque Oud Palao. FdB Parisian har börjat växa på en lite, har jag märkt... Ros är lika mångfasetterad som oud verkar det som. Och när de då ofta kombineras blir resultatet ganska skiftande...
Grand Soir var fin, om frugan gillar den kanske vi köper en flaska tillsammans. Annars får det nog vara. Baccarat kan det nog bli ett flaskköp på, 30ml.
Skippa POAL från FM och gå direkt på Promise. Hästlängder bättre!
